Wanted To Buy
Cubes
WTB:
1: Bottom half of cluster surround or the entire trim
2: Drivers kick panel under the cluster surround
3: Trim that goes around the gearstick boot.
4: Main headlight switch
All parts are for a R32 GTS-T
PM me details or txt me on 0433 522 234
Cheers Tim
got trim round gearstick and maybe switch have a look tommorow
hey looking for r33 or r32 stockies with decent tread to go through id inspection. pm me or txt 0422164665
Gilly has my 32R wheels at the moment for the same reason, if time permits you more than are welcome to borrow them. 100% tread on tyres, and that's how I expect them to return ;)
hi im new to skyline aus,
im proud owner of 93 rb25det gts conversion.
to finalise the conversion I require a few parts, currently looking at whats available and prices I would be chasing.
Items:
- R33 LSD to suit turbo motor and auto trans
- R33 brakes/rotors to suit stock r33 turbo *5 stud*
- R33 gtst stock turbo timer setup
Extra Info:
just chasing prices and information for possible purchases
Contact Details:
pm or email: [email protected]
Price and price conditions:
second hand parts but in good condition or aftermarket, ADELAIDE location, just chasing prices for now
after a genuine gtr wing/spoiler as i have a fiberglass one that doesnt cut the cheese with me, plus hairline cracks arent my fav either.
not looking for a boot + spoiler combo just the spoiler by itself.
cheers
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
