Wanted To Buy
Cubes
Looking for r34 4 door driivers door glass, weathershield drivers side and ignition barrel and key.. Needed asap for a friend who had their car broken into and attempted theft..pm me if you have any of these. Thanks!
Wtb - drivers side r33 s1 power window regulator with motor. needs all rubbers and stuff in perfect working order as my window pops off the rails everytime it goes up because of a bad rubber. need it ASAP so please let me know if u got one
R32 Cat Back Exhaust. Obviously can be from a R32 GTR/GTST Coupe/GTS4/GTST 4dr
3-3.5" in size
Must have "middle muffler"
Would prefer NO CANNON at the section of the exhaust i.e. Twin 3" tips out of a muffler, single 3" tip etc. HOWEVER may be interested in one which has a "Cannon"
Must be close to legal dB reading i.e. 90dB (A) (I think the sound tests are done at A weighting levels???)
PM or contact me on 0401 317 009
require ASAP.
Cheers,
David
Edited by R32Abuser
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
