Wanted To Buy
Cubes
URGENT!!!!
Need r33s1 waterpump in good working condition.
need asap due to vehicle running out of coolant and its my daily driver.
contact me on 0422360999 (text me thru the day untill 510pm) need by friday/saturday
Cheers aaron
Hi guys
Sadly some a**hole stole my R33 and took it for a whirl and helped themself to some items. Also sadly unsurance are being dogs and wont pay out on a technicality. SOOO i need some help im after the following:
R33 series 1 Front bar (can be any type prefer white if possible... also i have a front mount if they will affect anything) hell ill even make a series 2 fit lol
New airbag (was stolen)
new ignition barrel
Boot carpet (they pulled out the custome interior i had..) also need the panel that covers the battery area as well.
spare tyre/jack if theres one floating around.
any help would be HEAPS appreciated. im based in Klemzig area as well
Hi guys
new ignition barrel
sorry to hear man,
got spare boot interior except bit that covwrs battery...
new ignition barrel
Ive got a passenger air bag out of a series 2 also have a spare jack.
R32 gtr apexi pod filters. can get new for 280 online so if anyone's got any better pm me.
Hey sean, just a heads up, the 3A Filters from supercrap/autobarn are rated better than the apexis and only cost $30 each... Wheels did an AFM shootout a few years ago and they slaughtered the apexis in terms of filtration and airflow...
http://www.australianauto.com.au/HTML/Images/Air%20Filter%20Shoot%20Out.pdf
-D
i would guess the slower the flow the quieter the induction noise
Theres really not a huge amount of difference in noise that I can tell... I run Trust M pods atm but will be replacing it with the 3A - 3A filter is a dry type (no oil required) so its a little friendlier on your air flow meters (oil from filters can accumulate and get baked onto the afm sensor wire)
-D
legends. hey ben you still want that steering wheel ? your in town now ey. ive still got it, it didnt sell with the 33.
might go get some of the 3A filters one night this week. cant stand the standard airbox it makes no noise what so ever haha.
lack of noise = police friendly. I'd be going for lack of noise as long as it doesnt compromise performance.
Going from box to pods doesn't make that much of a difference in terms of noise (that I've found) but they do make a diff in performance (relatively speaking, the arc air filter/custom box is supposed to be good but I know nothing about it)
Pods are easy and cheap to replace, but you have to go to the trouble of making a cold air box and intake duct to isolate them from ambient engine bay temp, whereas a box filter generally has this by design - which is why the aftermarket hiflow filters that slot into the stock airbox are popular but again, i know nothing about them...)
-D
A mate of mine is hunting a R33 diff.
Would prefure a 2-way or the like, but a standard diff to get him out of the sh!t for now will also be great. :domokun:
Contact myself, 0433830055
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
