Wanted To Buy
Cubes
Items:
R34 front Bar Aero type ( Nismo body kit ) any condition as long as its repairable.
Extra Info:
I am really just after the lip
Contact Details:
PM please
Price and price conditions:
Whatever is fair
The nismo bodykit doesnt have a lip or even provision for one:
The aero/altia kit - the lip is in-built
You're after the nissan factory-option lip (I have one on my car). Note, there are two types - one for turbo and one for non-turbo (allows for the vent on the passenger side of the bar). The picture you've included is of the non-turbo type. Either way, knowing the right words/search terms might help find one. Took me about 3-4 years of searching to pick up a genuine one second-hand, but I've seen them come up a lot more in the last 12 months than they used to. You can pick them up in fibreglass from places like carmate.
After a 3" front pipe to suit R32 with RB25. Dump Pipe not needed.
PM or contact me on 0407 633 573.
Still looking for one, would rather find a second hand item before buying new.
R32 GTR Right Hand Front Guard with no indicator in Gunmetal Grey with no dents or scratch's. PM or txt me what you got, 0433 522 234.
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
