Wanted To Buy
Cubes
Wtb 17 inch rims suit 4 stud (4x100) in decent ish condition, can vary, without tyres preferably unless it has 205/40/17's
for a nissan nx-r as its now my new daily driver. Pm me with details or txt - 0422360999
not looking to spend to much (couple of hundred)
hey looking for a set of rear 5 stud hubs.
doin 5 stud conversion on my laurel but the rear hubs i bought dont have bearings and apparently you cant buy the bearings seperate from the hubs.
cheers.
Free or cheap as chips , rb25det NEO r34 alternator not r33 not the same config
Gtr r34 alternator would work too
Can be dead or alive and needs pulley still
Must have a unbroken case
Its for a project to benefit sau in the long run
Pm me
Cheers
also after some 235/40/18 tyres (prefer as much tred as possible)
cheers all
Urgently Wanting To Buy: R33 series one front bumper, MAYBE reo bar if i cant straighten mine out.
Can be any colour (although my car is black), stock or bodykit, as long as its good condition.
My brakes failed and ive stuffed up my front end and need one asap so i can get to work.
Reply via here, or more preferably via my mobile 0401 031 323 Much appreciated :)
Bumper has been purchased.
I now urgently need a r33 series one front bar reo. cheapest ive seen so far is 180 from a wreckers, so if you can beat that and you contact me on my number provided above before 5pm today you have yourself a sale :)
WTB:
S13 / R32 on front seats with rails (pair). Fabric doesnt have to be in the best condition, as long as they have rails complete, the slide mechanism works and seat structure itself is fine
For a friend's project car
Contact via PM
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
