Wanted To Buy
Cubes
im chasing a new breather pipe for an rb25 between the 2 rocker covers, mines split and since its not my daily am not in a big rush but need to get it changed as it slowly leaks oil.
if someone has one or knows where to get one would be much appreciated.
im located in southern suburbs
cheers madaz, didnt want to go there and pay thru the nose if there was someone else out there for cheaper, but if nissan can do cheap parts i guess its worth buying genuine.
Hi guys and girls, I am after a r32 gts-t front cross member, lower control arms and front hubs.
i am turning the GTR to RWD and need these bits. I am willing to pay or swap for some r32 gtr bits
that I dont need.
What I have is: r32 gtr front crossmember,arms ,hubs and front shafts
ABS module, front , middle and rear wiring looms, abs,hicas and attessa cpu's
hicas pumps, rack and lines.
any help would be appreciated.
cheers, troy
R32 GTS-T coilovers.
Not too fussed on a specific brand but must be base height adj, camber if possible, and stiff as fk spring rates.
Suit drift application.
Regards,
Weez.
Items:
2x RB26 AFM's
Extra Info:
needed ASAP!!!.
Contact Details:
either e-mail me on. [email protected], or text me on 0417000545!
Price and price conditions:
price im not too fussed.
best condition available!
After RB25 S1 (green label) AFM plug. I am pretty sure the RB20 one's are fine too. Let me know with what you got via PM please.
Thanks
WTB an R33 S2 rolling shell that is NOT defected or written off.
Must be registerable.
Willing to pay around 2k.
call or txt on 0429027204
Edited by R-Type
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
