Wanted To Buy
Cubes
under pressure yes, once the tyre is deflated you can get them off easily and safely. Learnt how to do it on many an army truck when we did our driver's courses. Inflation is always face down or in a cage just in case it springs off
Front 215/45/17 Tyres - Something reasonable quality
Rear 235/45/17 Tyres - Anything above 50%
R32 Roof lining
R32/R33/R34/S13/S14/S15 Steering rack bushes to hold the rack in
Anybody have a press I could borrow for 5 minutes? Just need to press 2 items which are already off the car.
R32 Roof lining
How soon do you need rack bushings ? I have superpro kit to fit so my factory ones are coming off ? Low km r34
R32 actuator
R33 Series 2 driver side seat(without rips)
R33 2 door driver side A trim panel(without holes or speaker boxes)(dark grey/black)
R33 std Cat converter splash guard(guard only)
R33 floor mats(must be good cond)
R33 camber kit(front or rear)
R33 series 2 GTst aftermarket computer ECU
PM me
Edited by cosworth1971
WTB R33 GTR Skyline Cluster that says 320kms...or a cheap stock R33 gtst one...mine as stopped working..plz PM me if you got one for sale Thanks
i have R33 gtr cluster with the standard 180 on clock but also have the 300kph Nismo add in speedo stuff in the for sale section
WTB: R32 non-turbo
Looking for a P-plater mate, so he wants a non-turbo R32. Would prefer 2 door, but will consider 4 door.
Local (Adelaide) or interstate is fine.
About to hit up the classifieds to look for one, but figured I'd ask here for a quick referal.
PM me.
    • Because there is still an engine underneath that turbo. PSI is not a measurement of power, it's a byproduct of resistance. What would be really decent is to have a CFM gauge on the output of a turbo to see how much it's actually pushing. 21psi (as an example) is not the same amount of air at 3000rpm as it is at 7000rpm, even if the boost controller is controlling boost at "21psi". The engine is inhaling and exhaling way more air at 7000 than at 3000, even if it's less efficient.
    • don't want anything more or less, I don't really understand why the torque still goes up to 6000-6500, while the boost peak is around 4000. if it only comes from the cams or from the boost controller etc.
    • I'm not sure you understand the physics of what you are asking. Can you draw on the dyno graph what you want to have happen? I'm thinking this is a functional impossibility here, unless you chose a turbo literally so laggy that torque is at max at 7000rpm and artificially choked prior to that. Power and Torque are intrinsically linked. Power is just Torque over time. What you're really seeing in the torque graph is "Power per RPM" if that makes any sense whatsoever. You still get more power at 7000rpm than 5000rpm, because it is "power per RPM" and you have more RPM. at 7000 than you do at 5000. You still feel more powerful at 7000rpm. The torque graph will influence the rate of power increase per RPM.
    • Welcome!  If possible,  would live to see some pics. How long was it away getting the work done? Hopefully it feels like a new machine.
    • yes indeed the graphic format makes a visual difference but there is on average 120nm more between 4000 and 6000rpm on the curves it is not nothing. you are right, the cams influence the torque curve. I was able to chat with one of the Hypergear tuners, he confirmed that a boost control allows you to manage the pressure after the spool. the absolute pressure (psi) on the graphics is measured where? It seems that the cams affect the maximum pressure depending on the regime but I may be wrong.   not pleasant to drive before 4000? if we spend our lives between 1000 and 3000 rpm as you say then we might as well just run diesel turbos
