Wanted To Buy
Cubes
after a series 1 r33 dash cluster reading around the 130 thousand mark (old ones stopped ticking over and need a replacement
any help is appreciated text me on 0422360999 for a quicker response
Aaron.
I have one but its 149k kilometers... and for an automatic....
Im about to put it on ebay or throw it in the bin.
Item
R34 steering wheel, with airbag.
Good condition and Ill pay what its worth.
contact details
pm me.
Auto or 5 spd
S1 or s2 ?
How soon ?
might have my s2 5 spd up for sale soon
silver and black
gotta fit my carbon and leather nissan airbag momo
After a boost gauge. Condition etc doesn't matter, I only need it to check the accuracy of my EBC so won't be mounting it in the car. Looking for something relatively quickly. If you have something send me a PM!
I'm after some Lenso D1Rs as I clipped a kerb and destroyed 2 on mine.
Size - 18x9 +32
Finish - Matt Black, red lip
Condition - new or used
Price - the cheaper the better
Cheers
Aaron
I'm looking for some cheap 17" rims to fit a V35 Coupe - standard V35 rims (17x7.5 front, 17x8 rear, +30 offset) would be perfect, or something similar. I'm not too fussed about gutter rash or scratches, just want them to fit old tyres for motorkhana type events. Anyone got suitable rims in the shed?
Edit - with or without tyres, tread or no tread
Edited by GeeDod
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
