Hi guys got a bit of an emergency here, i have a r32 gts-t/rb20det and i have just blown out one of my rear heater hoses, I managed to get the car home and have had a look but i have no tools or a replacement hose, i was wondering if anyone on the northside(I'm in daveron park) is able to come around with a replacement hose and some tools to help me get this sorted as i have to use the car to pick our 2 kids up from school at 3pm. I can be pm'ed on the forum or text messaged on 0403606243(phone only texts no calls recieving on phone) anyone able to help would be much appreciated can throw you $20 and 6pack for the trouble if able to help.
Cheers Steve.
Cheers Steve.
Steve, I hate to be the bearer of bad news, but the odds of someone right now sitting at home with nothing better to do, and has an RB20 rear heater hose, and can get to you and fix it for $20 plus a six pack (which I am sure wouldn't even buy you the hose itself), all within the next 2 hours is worse than one in a billion. If I were you, I would be making other plans.
The good news is, that if you can find some copper pipe about the same diameter as the inside of your heater hose, pull the other one off the heater hose off the heater core at the firewall, and join them together with the copper pipe and some clamps. I ran around 'fixed' like that in my R34 for months a few years back. You lose your car heater, but at least the car will be usable.
    • Anyone want to make me an offer to take my v36/g37 3.7l manual coupe in full? Off memory it was low 100k km but the battery is flat so can't tell right now. What's wrong. I had engine problem's that led to a nice clunk. It made it home but it wasn't pretty for the last few kms. Happened under revs. Sounds like bottom end.. never got around to fully checking or fixing it so the car has sat still and unregistered for a few years. Minor bump in front end set the pedestrian protection under bonnet airbag off and that was meant to be repaired, but while waiting for the repair (parts to come) I got the engine problem. The rest of the car is in decent condition. All drive line is good. All interior is good. Leather interior. Wheels in good condition and decent tyres although the ps4s are likely a little too old now it's sat still. Colour of the car is pewter off memory, the dark grey colour. In Camden NSW. Would need a tray back pickup.
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
