Looking to buy a R33/S13/S14 as a daily CHEAP :) auto/manual turbo/na what ever.. im ginger and will haggle :P
could trade with our 2006 VZ Acclaim with coin our way worth about $8500
basically the wife is trying her best to help me getting my track car done, we already have her vl calais up for sale (may trade this also) and now trying with her vz, then any money we get goes into mine :P
pm me with anything you have!!!
^^^ Hey Danny, Just put my 33 up for sale... probably not quite what you are looking for...
http://www.skylinesaustralia.com/forums/topic/354186-for-sale-thread/page-455
definitely like yours bud, but wouldnt free up me any coin for my tracker :( found one today but the guy wont answer his phone or reply to msgs :( found another with a blown headgasket at a great price but very risky.
looking more 4-5k so we can sellt he vz quick for 7500, most are 8500-10, then i get more toys for mine weeeee
I didn't know where else to post this but does anyone know a place that stocks redline oil or royal purple hps 10w40 5L oils? I've looked everywhere I know of and that's close but still can't find any. Any help would be appreciated. Pm me if you know of a place
Thanks guys
Thanks guys
heya bud maybe get on facebook and ask driftsquid (Jakes Jones) he is sponsored by royal purple he should be able to help
Thanks guys
Sleek a Spares at Langford St Pooraka can get Redline. Got it from him before at a great price
WTB/S want a cat back for the missus new daily, just bought a car with a loud system and want something stock or very quiet :P can swap with current system
Have one, came off of my '33. Have photos if interested, its in good nick. I was the one that bought the bonnet off of you late last yr :)
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
    • Here is picture of the rear brackets again seeming to have eating itself or corrode or whatever. Can’t describe it , hope someone could explain this
    • No i am in the uk so maybe road salt etc but checked rear and same story where handbrake cable seems to have eaten part of the bracket. Have emailed alpha omega waiting for reply
    • I've not looked at a GTR without the booster there. Is the hole and mount on the firewall not just the same as GTSt? I would have expected it to be. Nissan don't change panel stampings if they don't have to, and you'd think they'd just order/design the booster to mount to the same place.
    • They have all sorts of "failure" modes. When they are brand new, the can either be very very tight, or reasonably mobile. If they are reasonably mobile, you'll probably have a good start. If they are very tight, then they can catch/grab at every little motion, and they mark the ball or the outer race, tearing off whatever teflon lining is in the outer race, then they can rapidly degenerate from there. If they get wet, they can just rust. They are just steel and will turn red pretty quickly. Water can get in behind them and sit and cause them to become crunchy and then proceed to tear themselves up, as above. Same with grit and dirt. Manufacturers and OEMs of the arms that use them will tell you that because they are teflon lined (well, the good ones, anyway), you shouldn't grease them. If you do grease them, then the grease will catch any passing grit and dirt and hold it in place where it can cause damage. Race teams that have them will lubricate them thoroughly. They will also inspect them every 5 minutes and replace them every 10 minutes, if need be. Some manufacturers of arms will provide dust boots. These can help, but they are seldom perfect, and sometime just make the situation worse, being a place where crap can collect. I have made nappies for some of mine with PVC sheet and race tape, to try to minimise the access of crap. When they wear, you can get a tiny tiny amount of movement between the ball and the outer race. This will make clicking noises. It will also make the arm have "slop" in that the tiny amount of movement available at the inner end of an arm can cause a lot of movement out at the outer end. 0.05mm at 5mm from the pivot becomes 4mm 400mm away from the pivot. If they are too tight and binding, they impede the proper motion of the suspension arm and put loads into it and the rest of the suspension that are not supposed to be there, and can cause failure. Think broken welds, broken threaded sections on the adjustable parts, mounts ripped off the chassis, etc. All of these are possible, which is the main reason why they are essentially illegal on the road in Australia.
