Wanted To Buy
Cubes
wtb R33 S1 Indicator stalk as mine is doing that clicking and smoking thing at the moment. Don't have a fog light switch atm but a stalk with one on it would be orsum as i plan to hook them up.
Also after someone with the knowledge to show me how to replace in person lol!!! There'l be a 6pack of whatever you drink in it for ya <3
I'm after a set of r34 gt-t wheels
or r33 GTR wheels
or PM me to point me to a wrecker who is sitting on a few sets
or anything else in 17 inch to fit a stagea rs4
my tyres are getting low and i dont want to buy 4 newies and be stuck with 16's for another year
Thanks
Dan
Japanese Import Spares just got a set of R33 GT-R wheels in, and Sinergy Motorsports have a set of 33 GT-R wheels for sale too, 1k they're asking.
i want to buy four, what you mean how much im offering lol
how many australian dollars are you willing to give another person of which you do not know , for 4 x stock wheels with tread as this ''person'' has 2 sets and may be willing to let one set go for the right amount of australian dollars
or r33 GTR wheels
Thanks
Dan
Andrew aka Blue32 had full set of R33 gtr rims without rubber for about $1100 dont know if there sold (edit there not sold but he has a bit of interest)
>>PM Andrew Here<<
>>Pics<<
or r33 GTR wheels
Thanks
Dan
PM sent - Thanks Steve :-)
pm's recieved and thanks
looks like i'll have to narrow my search
i'm looking to spend no more than $1000 with something i can bolt on and dont need to mess with (i,e tyres) or something far cheaper to which fitting tyres is not going to send me over budget.
thanks to all those who have helped (and please continue to do so)
but seeing the prices of some r33 gtr wheels getting around its beyond my allocated funding
Dan
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
