Wanted To Buy
Cubes
WTB: 17 inch rims.
pair or full set.
same size front and back min 8inch with tyres or without.
something like gtt stockies or some meshies etc.
CHEAP..
Unless its a weak-spec screamer on dump... Screamers should be custom made to suit the wastegate & manifold setup.
Screamers on I/W turbos is like putting socks in your undies
Well since someone broke into my car late last year, im after some parts:
* R33 front bar-stock gtr or aftermarket, preferbly in black
* FMIC, only core was taken, have 3in piping still
* R33 2 dr, driver side door, need it for window
* cheap pod filter
Thanks in advance
hey guys
i need the pipe that goes from the return intercooler piping to somewhere.....its near the stock bov...mine has a mad split in it and its leaking boost....i have attached a pic to let you guys know what i am talking about....
and i need it asap
You can borrow mine Krishy untill you get a chance to get another
can i just buy if off ya steve...but if not then borrowing it would be a good option.....can i get it today if possible????
hey guys
and i need it asap
Borrow Steve's, then order one from Nissan. Ask someone with FAST to get you the part number.
yeah can possibly get it too you tonight i have to head down pt adelaide tonight and im at home at the moment so will endeavor to take it and drop it by your house or catch you up some where
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
