Wanted To Buy
Cubes
WTB :
An R32 right hand headlight (Projector)
Clear right hand front indicator
Speedo gear that goes into the side of the gearbox for an RB20. Is an RB20 one the same as a RB25 one?
Someone to drill and tap 2 holes. Can come to you depending on how far you are.
Tobias, if you're drilling into sheet metal you won't need to tap anything but you will need to fix it with a nut on the other side.......where you drill is crucial too.
I'm assuming that you're trying to attach those gas struts, yeah?
yer mate :)
Only thing is i have the go into the wheel well as going through the fender isn't sturdy enough and i don't think there is enough room for a nut.
Edited by Blazk
Are you SURE you need to drill a hole Tobias? They should be bolt-on - normally you undo one of the mudguard screws and put it under there. Bring it over here and I will have a look/install it for you.
RB20 sump and Cefiro castor rod mounting brackets.
if rb25 sump is the same u can have the one off my old block..
just have to remove it thats all hehe
