need a brake master cylinder as mine is leaking.
fuel lid / flap any colour will be fine
and the bit that holds the gear stick boot in place duno what its called
car is a r32 :thumbsup:
Buy item: 3 inch cat back muffler ( new/ near new condition) , deep sound , nice note not too loud, sound like r33, rb25det should sound. Prefer kakimoto brand if possible. / turbosmart plumb back bov for r33 ( gd condition)
Contact Me or leave Me a massage on 0401301886 , SA only. Ta
Got an Apexi dual N1 system here that came off my GTR bugger all km's on it, will fit GTS-t $700
tried calling u.
Still hunting for the 180sx sunroof latching mechanism? Anyone got one in place?
Otherwise I'll just ram something in there and stick the flamin mongrel open haha.
Regards,
Weez.
Hey guys,
I'm looking for the wires/cords that are for a JVC KD-R606 head unit. Took the unit and the face out of my old car, forgot to grab the connections /facepalm
Not sure what they are worth, but if someone has some, or can get some I'll pay around $50 for them.
Cheers guys
I'm currently after a A31/C33 RB20DET engine harness (one on the ecu side)
I have just baught a R32 one and realised it doesnt fit, so im returning it.
If anyone has one can they please send me a PM or SMS on 0404 313 918.
Thanks!
Need a set of R34 GT-T stock wheels for my GT-T.
If R33 stock wheels clear everything, they'll be fine as well.
PM if you know of some for sale, but prefer R34 wheels.
i got mint 34 gtt rims with centre caps and 90% tires...$450.....text on 0415 23 23 97.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
