Currently chasing a few things.
- R33 stock springs either coupe or 4dr as long as stock
- R33 glovebox
- R33 Steering wheel (must be near mint no rips or sun damage etc) and must be non- airbag s/wheel
- R33 4dr driver's door power window amplifier (R32 4dr may be same)
PM me if you have any. Cheers.
Have a set of 4 standard springs from my R33 2 door, nothing wrong with them, just no longer needed
Here is a link to them http://cgi.ebay.com....=STRK:MESELX:IT
Can contact me on 0433349400 for more info
Chasing a cheap front seat. Out of anything really as if for a track car. So R32, 33, etc whatever is cheap. PM me if you have something. Cheers
Hey mate, I have an S14 drivers seat with rail if you are keen?
WTB : Stock 1998 series 3 R33 GTR stuff.
R33 GTR standard ECU.
Front bar (preferably black).
Rear parcel shelf.
Rear driver's side inner trim.
Stock turbos (can be from a R34 GTR). Must be in working order and good condition!
Stock injectors.
Stock AFMs.
Also need coilovers for the 1998 R33 GTR. Must be in good condition and suitable for everyday driving on the street ie not too firm.
As well as an exhaust system including a cat that is not too loud and does not drone.
Looking to return a car back to stock so only really interested if I can get the lot. Don't want to end up with lots of parts that I then have to sell myself.
This will be coming out of my pocket for someone else's car! Which really f***s me off. Will need to swap over parts if you're able to help in that regard. Reacharounds for all.
Thanks guys.
r33 rb25det engine+loom and etc for det conversion.
need one as i am going to turbo my na r33 but my mate also wants to salvage parts off of it for his drift car.
pm me pricings and etc.
thanks guys :)
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not!
    • So the other thing I got sorted over the weekend was Z1 oil catch can install. https://www.z1motorsports.com/z1-products/z1-motorsports/z1-q50-q60-30t-baffled-oil-catch-can-kit-p-23546.html It was a good kit, most importantly it came with preformed silicone hoses in the right shapes rather than trying to bend/join regular straight rubber hose. It did come with crappy spring clamps not proper hose clamps so I ditched them On the down side, it is made for LHD cars and RHD cars have the main ECU harness running straight through that location, I ended up bending 2 mounting brackets so the loom is up against the brake master cylinder compartment wall to make room for it....otherwise everything fit without modification Intercoolers off on both sides, but there was enough room to get everything done without disconnecting (and therefore having to re-bleed) the coolant lines. Each is mounted with 4x 12mm headed bolts, plus in and out side hose clamps (7mm headed, nice) and 3 electrical connectors on the navigator's side which were a real pain to undo (probably for the first time in 13 years).   Also one of the mounting bolts on the driver's side was cross threaded, thanks Infiniti/Nissan workshop mechanics. On the navigator's side, the catch can plumbs into the factory hose that goes from the cam cover PCV back to the intake.  This is the 2 new hoses in place. All simples and direct fit On driver's side, there is a bracket provided that mounts to the throttle body, they even provide slightly longer bolts to allow for the bracket thickness which is nice (although, they don't have captive washers like the factory bolts of course) In that pic the main loom brackets are not in place, once I had "adjusted" them across it now sits up against the panel and just clears the OCC The remaining problem with this is emptying it; currently you have to remove the 3x m4 bolts that hold it to the bracket and both banjos to remove it (probably dropping the banjo washers at the same time) pull it apart to empty then replace. I do have some fittings coming for a remote drain from underneath that will also add a little capacity...it is very small and will need to be emptied every oil change to be sure.
    • Noise sounds to me could be either wheel bearing related (have had similar from bearings going) or that tail shaft is still loose. Or something like a heat shield touching the tail shaft.
    • You wouldn't get away with saying the opposite, if you were there.
    • Do some wool fluff testing on the vents
