I get my license back real soon now... 5 weeks away so i need to start thinking about getting a new whip so...
if anyone has a VT (or onwards) stationwagon in decent condition well maintained, tow bar, etc etc that they're looking at selling or even thinking about it swing me a PM and I might be interested!
Cheers all :)
Anyone got an inlet manifold to head gasket lying around for RB25???
Need one like urgently. Nissan don't have one in stock, and hoping to fit it by tomorrow (or asap) to finish tuning my car. My boost leak is apparently coming from a leak between cylinder 5 and 6 due to blown inlet manifold gasket :(
PM me please :)
needed by tomorow S13 power steer line
hey need tomorow the short metal power steer line between the back of the rack and the knuckle on the pinion
its on the back of the rack itself and is only about 300mm long, its mad short
i crushed it when i put my engine back in the car or taking it out one of the two
but i have a private track day monday and need it changed
ADELAIDE please call on 0425313447
PM me please :)
All sorted now, thanks to nicr4wks :thumbsup:
Hey guys,
WTB: Subaru Forester 03-04 Model
Model: XS Luxury or XT (Turbo :thumbsup: )
My missus had a car accident the other day and now she needs a new one and it has been on the cards for a while.
Anyone know of one for sale or if you have one pm me and go from there
Cheers, :cheers:
Matty
Hey all
Was wondering if anyone has a climate control system for their r33 laying around in good working order as the one in mine, the off button decided to break (i beleive its an s1)
(not important but if anyone has any mirrors for an r33 in working order, fold in and out in the red wine colour, dont have car with me or colour code that would be sweet)
antenna doesnt go up or down so i need one of thoes in good working condition also
cheers, aaron
Hey all
cheers, aaron
lol same problem hey?
my off button broke aswell thought i found a site on ebay in adelaide that sells them
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=360322358382&ssPageName=STRK:MEWAX:IT#ht_3348wt_1139
that should help ya out mate
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
