Items:
V35 sedan standard front bar
V35 sedan aftermarket side skirts and rear bar
V35 sedan HID right headlight
19" or 20" rims+tyres in 5x114.3
twin 3" tip exhaust x2
Extra Info:
preferbly in factory pearl white
not too fussed on offset. dont really mind chromies as I'm just going for a show pony look
Need full headlight including ballast module and globes
Contact Details:
pm on this site
Price and price conditions:
i can get a full kit for around 1k, so cheaper than that if possible
headlight not sure, i bought after market set for $300, i understand these are HID though
no more than 1k, found a set for $600, but wanna see what other people might have
Hey guys I'm looking for a rb20 wastegate actuator for my rb25.
Correct me if I'm wrong but the rb20 actuator runs constant 10psi compared to constant 8 psi with rb25 actuator when you ground solenoid.
Thanks
Edited by Vlasi
NEED the following for an r32 gtst:
Drivers 1/4 panel - black preferred, in exc. cond.
drivers door - again black, same as above.
Would like the following :
std exhaust to get through regency
r32 gtst std diff
rb20 engine mounts - the metal brackets, not the rubber mounts
r32 gtst headlights in good nick
Let me know how much etc,
cheers.
BTW, if you have parts (like a diff) id prefer if it was ready to go, not "ill pull it out next week" which never seems to come.
Edited by Bl4cK32
