i have ROH shift R the multi fit 4stud on my skyline at the moment but im converting to 5 stud so on friday they come off rubber is pretty used
that is what they look like bear in mind that picture is 5 stud mine are 4 stud
WTB: tail light covers 4 R32 4 door or any info on where to buy
also any useable wheels to suit R32 Gts 4 stud will pay well 4 a nice set as atm looking 4 a package deal
btw arent we meant to be using this template :O
Items:
Stock boost solenoid for R33 Series 1
Extra Info:
I hate regency :@
Contact Details:
PM me/ email [email protected]
Price and price conditions:
not sure how much it is worth
YES we are
Items:
2x 235x17x45
Extra Info:
just needs a bit of tread
Contact Details:
PM me/ or get my mobile out of my profile
$20-30 per tyre $50for both
btw arent we meant to be using this template :)
WTB asap: R32 GTR Stock suspension - looking for complete strut assembly for swap out. Also willing to buy from adelaide wreckers if you can point me in right direction.
Contact via PM or email to [email protected]
thanks
Wegs
Edited by wegs
WTB lowered springs to suit R33 S1.not rediculously low.
and dont say ''get coil overs bro'' i have better things to waste my hard earned on.
contact; PM
cheers
Edited by craig R33
looking for a rb25det series 2 engine complete with turbo, ecu, loom.
everything to drop into r32..
obviously want something with lower km's and cheaper than wreckers..
so about 2500 if not less!
if u have one or know anyone let me know
0433290801
cheers adrian
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
