surge tank fittings are usually placed in the middle of the tank making the fuel inside just splash around etc
Swirl tanks are usually round with fittings placed on the end causing the fuel to "swirl" inside, there for fuel will always be available to the inlets/outlets.
Marko go a swirl pot instead of a standard surge tank.
Outlaws in the city can help you, thats where i got mine but in a 4L
Exactly what im looking at if nothing comes up by Friday, was going to put a baffle in a standard tank to stop it from splashing around otherwise tho. Ill give outlaws a call tomorrow, cheers for that. The one im looking at is on the net $100 for 2L tank
Just to clarify on the fuel pump bit, as I just found out, ill be needing a minimum of a bosch 044 or equivalent and at least 2L capacity surge tank :( if anyone has anything let me know asap otherwise ill have to ditch more cash at the hunk and go buy new stuff this week :wacko:
Bosch 044 and bracket acquired, thanks a bunch to frankyp11 absolute champ!
URGENT -
WTB - series 1 r33 type m front bar with indicators, and rear pods, preferably in the burgundy stock colour. would save a lot of headaches. still message me if you have in other colours.
will pay cash on pick up.
- few hundred dollars depending on condition and whether or not the front bar indicators are included. very keen for a quick buy so if you have this stuff message me.
Contact - msg me anytime on 0421549607
WTB:
1: Bottom half of cluster surround or the entire trim
2: Drivers kick panel under the cluster surround
3: Trim that goes around the gearstick boot.
4: Main headlight switch
All parts are for a R32 GTS-T
PM me details or txt me on 0433 522 234
Cheers Tim
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
