Wanted To Buy
Cubes
Fitting Defi gauges and chasing an adaptor for water temp that goes into the top radiator hose on a 34 NEO. I would even buy a complete hose that has an adaptor in it. Needs to have 1/8 NPT thread and 36mm from what I can tell
Adelaide prefered and will pick up
Good day ladies and gents..
I'm looking for a set of r32 4 door typeM side skirts and rear pods in any colour.
If you have such an item please message me on 0414190781 and leave me the details on who they look and what price you would like for them.
That is all cheerio!
Bit of a long shot, but im after some nissan n15 sss wheels.
Looking to put them on my daily as the 17's im running arent doing it for me at the moment + need repairs.
Looking to spend around 400 dollars max but am negotiable.
Hit me up on 0422360999 for quick reply (text prefered as im not always able to answer phone calls) or pm me and ill get back to you asap.
Cheers Aaron.
What do you call a good deal on a pfc I have a GTR pfc pro running a rb25det in my gts4 very easy to wire up for gtst and very rare being PRO I have it in the forsale section have a look make an offer
Hi all I am looking for a Z32 ECU for a S1 R33 GTST. Already have the Z32 AFM and Nistune being supplied by workshop...
PM me or reply to post :)
Oh and I look forward to meeting some of you soon from the SAU SA club :)
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
