I'm after 2x legal tyres. 1-2mm up from legal would be great. As for size, they are going on R33 stockies so whatever will fit, R16 225 50 seems pretty common. As cheap as possible.
They just have to tide me over until my replacement rims arrive next month.
Thanks
Aaron
Looking for some CHEAP 18" tyres for an event. They are for a V35, and to fit on 18" rims. OEM sizes are 225/45 front & 245/45 rear, so something around there would be good. Rears just need to have a bit over legal tread, would prefer a bit more on the fronts. Let me know what you've got.
Cheers,
Geoff
Hi, I am after a series 1 auto gearbox for an r33 ring/text 0418842599 Thanks, Ryan
I left a S1 autobox at japco when I got them to do my transmission swap, give Frank a call and tell him I said you could have it ! :whistling:
WTB:
-Good condition r32 Gear Boot Leather Thingy.
-Good condition Left hand side r32 aircon vent.
-Good condition cd player/gauge suround r32.
-R32 GTR power fc + hand controller jetro or normal.
Thanks guys.
WTB
Crank Angle Sensor plug and 20cm of wiring (back to around the temp sensor wires)
I broke an air conditioner belt which flicked up, tangled around the thermo fan and snapped the wires that run to the CAS. I need to splice in a new plug and wires ASAP.
Thanks
WTB
Thanks
Give me a ring mate :) 0433368063
They said they don't hang onto used stuff lol, thank you anyways.
Still looking for one, seems that most people throw them away but wreckers want $500 or more... Willing to pay a couple hundred if I can find one if not I will just bite the bullet, thanks.
Edited by 21337
Got an R34 auto. I know it will bolt upto the engine and tailshaft. Maybe do some searching and see if the wiring is the same or similar.
$100
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
