Hi all, after selling my r33 not too long ago, im wanting another import as a project car
Can be s14 180sx r32 or r33
Only wanting to spend a few thousand, but need to have rego approved (or even rego on it, will add extra to pay for it) under 200,000kms prefer around 150ish and need to be running and rolling.
Not fussed on body condition aslong as its not defected or has major structural issues and prefer all panels on the car.
Throw me a message on here or via text on 0422360999
Cheers Guys :D
ITEM
R33 gtr rear boot lock assemble with flick down nissan badge (darker silver series 3)
CONTACT DETAILS
[email protected]
PRICE
$75-200 preferably cheaper due to the possiblity of the nissan badge being stolen and broken off again
I have an R33 GTR series 3 in very good condition appart from some as#holes debadging the boot last week. I bought it for $21000 2 years ago and I live in Pt Lincoln S.A where the roads are 2 unforgiving so If I was offered 18-19 I could let it go due to lack of use.It is white with white Enkei 17 inch racing rims lowered on I think tein suspension with Exhaust,HKS pods,APEXI FC, Intercooler, tint and cd player.Love the car to bits but the roads here are savage if you are interested e-mail me for picks and i'll try to get some compression numbers for you.It's conservately tuned and has been since i've had it at 212kws at the wheels
Cheers Guys :D
Sorry just realised you said 150ish not 15ish forget I wrote anything.
Cheers Guys :D
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
