A few bits and pieces i no longer need...
post-8257-1163752895.jpgR33 original side mount intercooler kit..........$95
post-8257-1163753003.jpgGauge pod - brand new...............................$10
post-8257-1163753249.jpg Original HYUNDAI steering wheel - brand new.$80
post-8257-1163753283.jpgAuto gear knob suits Ford cf finish................$15
post-8257-1163753321.jpgR32 Right hand side blinker slight damage....$30
post-8257-1163753347.jpgRear Louvre suits Ford fairlane/ Fairmont.......$50
Interstate buyers pay for freight.
Prices are negotiable... to a point. :(
https://www.sau.com.au/forums/topic/143712-sh-tuff/
I also found a headrest for Hyundai..... i'll throw that in with the S.W. :P
:P Thanks for the offer.
The wheel was going to be for the G/F's car as a spare but she's more interested in getting a new stereo atm so..... Thanks again though.
https://www.sau.com.au/forums/topic/143712-sh-tuff/#findComment-2689130
  • 1 month later...
  • 3 weeks later...
  • 4 weeks later...
