Hello all,
Before you tell me to search I'll let you know that I HAVE searched and there was alot of data to digest and I did but because there was so many different questions and scenerios I was abit unsure, I thought it was best to just open a new thread to make sure.
I have a small amount of mild mods to my car (turbo back exhaust, ebc, fuel pump, fmic, fpr) and I plan to keep the car this way. I really would prefer 250rwkw as I believe this would be the just right amount of power to move our cars weight, but for now I'd prefer a realiable car with less problems - as we all know the power you have the more problems you are likely to run into.
I am going to build a Jaycar DFA in a few weeks and after alot of research I believe this is my best choice as I am quite happy with the cars power at the moment but would just like to remove the small flat spot I have at 5000rpm on 12psi and if possible, but not necessary, get rid of the REAL R&R (viscous surge).
So my question: Given the amount of mods I have would an Jaycar DFA do what I want to do? That is, to remove the flat spot(s) I get, and if possibly the R&R?
Cheers,
Andy
P.S - who should I ask to tune a DFA? Or should anyone with experience tuning an SAFC/PFC easily be able to use one when given instructions on how to use it? Alot of people have built DFA's; whats the feedback recieved from tuners?
P.S.S - please don't recommend a PFC. I've already decided I won't get one until, and thats if, I get a new turbo/injectors/afm setup. And seeing how Apexi no longer are making them it might prove hard. :huh:
The longer you wait the harder it is going to be to buy a Power FC.
Have a look in the Stagea section and you will find my thread on using a DFA, SITC and IEBC on a Stagea. I have no R&R.
:O cheers :rofl:
PS, the standard turbo won't last long at 12psi.
they dont directly avoid r&r, ie: the safc doesnt have a button to disable r&r it just happens that when it voltage clamps the afm values, you end up in turn avoiding the r&r protection. safcII is now discontinued as well, so you need to go safc Neo
Thanks guy, yep I was refering to avoiding R&R. As long as the DFA can do that I'll be happy.
I can't manage to find a PFC for an R34 GTT anywhere now at all, so I'll be on this path for a while until I manage to find one or look into the ECU remaps abit further.
Have you seen this in the For Sales section
http://www.skylinesaustralia.com/forums/in...amp;hl=power+FC
:wave: cheers :blink:
Because the turbine wheels are ceramic as oppose to the usual steel and as such don't take much boost/heat. The R34 compressor wheels are nylon as well.
Cheers for the link Gary but unfortunately that doesn't suit my car. It seems like the DFA is just what I'm after.
I realise they tend to delaminate from the shaft when the temps get up but with a safe tune I dont understand why you couldnt run 12psi through it with all the support systems? Series 2 R33's have nylon compressor wheels too champ.
Cheers
Chris
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
