sigsputnik Posted November 18, 2006 Share Posted November 18, 2006 hi all, in my r32, i have an aftermarket head unit (a jvc) so the two buttons on the dash head are not used. i'd like to connect them up to something, preferably the head unit (e.g. next track, previous track). is this possible?? here are the buttons i mean: anyone have any ideas? cheers, sig Link to comment https://www.sau.com.au/forums/topic/143804-using-the-2-radio-buttons-on-r32-dash/ Share on other sites More sharing options...
mtopxsecret6 Posted November 18, 2006 Share Posted November 18, 2006 I wouldnt like your chances of getting it to work with your aftermarket radio like you want. there could be a way of doing it, but if you dont know electronics.. forget about it. You could use them for other uses, but they DO NOT handle high current through them, so be warned. Link to comment https://www.sau.com.au/forums/topic/143804-using-the-2-radio-buttons-on-r32-dash/#findComment-2683454 Share on other sites More sharing options...
SuAvE-1 Posted November 18, 2006 Share Posted November 18, 2006 I'd like to see them hooked up to a boost controller - high/low boost that would be very convienient Link to comment https://www.sau.com.au/forums/topic/143804-using-the-2-radio-buttons-on-r32-dash/#findComment-2683565 Share on other sites More sharing options...
mtopxsecret6 Posted November 18, 2006 Share Posted November 18, 2006 Good idea on use, keep in mind that the are momentary "on" switches. something coud be configured ith a bit of thought. Link to comment https://www.sau.com.au/forums/topic/143804-using-the-2-radio-buttons-on-r32-dash/#findComment-2683607 Share on other sites More sharing options...
sigsputnik Posted November 19, 2006 Author Share Posted November 19, 2006 hmm, thanks chaps. i had the dash off yesterday for another issue and had a look at the connection - they share a plug with some other stuff i think (only looked at it briefly). i might have a hunt around and see what i can find out. Link to comment https://www.sau.com.au/forums/topic/143804-using-the-2-radio-buttons-on-r32-dash/#findComment-2683723 Share on other sites More sharing options...
MBS206 Posted November 19, 2006 Share Posted November 19, 2006 If you feel like it, you could quite easily hook it upto an aftermarket radio if you're handy with electronics. Basically, if the radio has a remote control, you need to pull the remote apart, join some wires either side of the (Forward/Back) buttons so that they use switches on the dash. Then, desolder the IR sender, and attach a long cable to it. Now, mount the IR sender up in the roof (Aimed at HU), hide the remote behind the dash and use the buttons away. Obviously that's a "brief" over view, if you don't understand what to do once the remote isp ulled apart, this job isn't for you. Link to comment https://www.sau.com.au/forums/topic/143804-using-the-2-radio-buttons-on-r32-dash/#findComment-2683818 Share on other sites More sharing options...
mtopxsecret6 Posted November 19, 2006 Share Posted November 19, 2006 Possible, but not that practicle to achieve such a simple request. Link to comment https://www.sau.com.au/forums/topic/143804-using-the-2-radio-buttons-on-r32-dash/#findComment-2684149 Share on other sites More sharing options...
sigsputnik Posted November 19, 2006 Author Share Posted November 19, 2006 i had originally thought about using the remote in that way but couldn't think of a decent enough place to house the sender - could use the overhead light switch housing, i suppose. Link to comment https://www.sau.com.au/forums/topic/143804-using-the-2-radio-buttons-on-r32-dash/#findComment-2684762 Share on other sites More sharing options...
ceedub Posted November 19, 2006 Share Posted November 19, 2006 I use the button to turn on the "carputer" (laptop under the seat) Link to comment https://www.sau.com.au/forums/topic/143804-using-the-2-radio-buttons-on-r32-dash/#findComment-2684818 Share on other sites More sharing options...
sigsputnik Posted November 19, 2006 Author Share Posted November 19, 2006 hmmm...care to share how you connected your setup ceedub? Link to comment https://www.sau.com.au/forums/topic/143804-using-the-2-radio-buttons-on-r32-dash/#findComment-2684987 Share on other sites More sharing options...
ceedub Posted November 20, 2006 Share Posted November 20, 2006 hmmm...care to share how you connected your setup ceedub? Sure, will post up some pics later this arvo Link to comment https://www.sau.com.au/forums/topic/143804-using-the-2-radio-buttons-on-r32-dash/#findComment-2686595 Share on other sites More sharing options...
sigsputnik Posted November 20, 2006 Author Share Posted November 20, 2006 sweet!!! Link to comment https://www.sau.com.au/forums/topic/143804-using-the-2-radio-buttons-on-r32-dash/#findComment-2686611 Share on other sites More sharing options...
ceedub Posted November 20, 2006 Share Posted November 20, 2006 sweet!!! In the mean time have a look at an earlier thread I had in relation to a similar topic: http://www.skylinesaustralia.com/forums/in...p;#entry2687030 Link to comment https://www.sau.com.au/forums/topic/143804-using-the-2-radio-buttons-on-r32-dash/#findComment-2687046 Share on other sites More sharing options...
sigsputnik Posted November 20, 2006 Author Share Posted November 20, 2006 yep, already seen that thread - great setup, well done! Link to comment https://www.sau.com.au/forums/topic/143804-using-the-2-radio-buttons-on-r32-dash/#findComment-2687195 Share on other sites More sharing options...
ceedub Posted November 20, 2006 Share Posted November 20, 2006 to switch the laptop on the radio button provides a momentary contact: Basically find two points on the laptop (I used the docking port connection) that when shorted turn the laptop on. You could also solder wires to the laptop switch. Run these two wires to the radio button switch. There should be a small black connector with 2 wires in it that is located behind the stereo slots - connect each wire to it - done (Only the 'FM/AM' button works - I don't know how the 'tune' button is configured as yet) (I've added more pics to my thread if you want to see more details on the install) Link to comment https://www.sau.com.au/forums/topic/143804-using-the-2-radio-buttons-on-r32-dash/#findComment-2687371 Share on other sites More sharing options...
sigsputnik Posted November 20, 2006 Author Share Posted November 20, 2006 you legend, ceedub, thanks heaps! Link to comment https://www.sau.com.au/forums/topic/143804-using-the-2-radio-buttons-on-r32-dash/#findComment-2687441 Share on other sites More sharing options...
