A straight through pipe doesn't really make it that much louder now drone in the cabin (unless the exhaust is prone to do so anyway) just a tad deeper and gruntier sounding.
A well setup exhaust shouldn't drone in the cabin full stop.
agreed...my exhuast is pretty much a straight pipe from the cat back and it IS loud...but not drony and more than bearable on idle and low revs.
How about you just do the right thing and buy a new cat...
Think of the environment.
Think of the cancer growing in your lungs from breathing in your un-catalysed exhaust gasses.
Is it worth it all just for gaining a few kW?
those kind of emmissions won't cause lung cancer... not in short-term exposure anyway
lung disease, yes (eg lung fibrosis)
you'd have to be breathing in funes everyday for years to be at risk there
honestly, i did this to my car before i got a high-flow cat and i noticed no increase in exhaust note, and no difference in power at all!
so it begs the question, why bother?
mine mustn't be setup too well then. hehe!
Going back to the original question why would you go to all the effort of putting a straight pipe through the cat? its pointless, if a cop pulls you over its usually due to the smell or noise and then they'll send you to the transport department. There are performance gains from a straight through pipe, but its not worth it on your daily driver.
My car has a decent high flow cat but since i installed a power fc and had it tuned it is running quiet rich and i always get pops through my exhaust, sometimes very loud ones. will this destroy my cat pretty quickly?
yeh they might look like a cat but if ya blowing flames out the exhaust they might be a bit suss about that
ive have a stock r32 im running on the track. ive gutted the cat and taken the rear muffler off. will i blow flames?? if so, cool!!!
and will i notice much difference without it? i havent tried it yet, have to wait till next weekend.
i will have a 3'' system on it by feb next year but for now its honkin ok.
Edited by johnGTS-t
there is almost no difference between a 'highflow' cat and a straight through pipe in terms of performance...
I know because the 2 bolts holding my cat to the front pipe came out last week and I was driving around for a few days with no muffling of any kind... the noise was deafening and sounded like crap below 3000rpm... I was even turning the ignition off at light because I was so ashamed...
now its fixed the performance difference is hardly noticable and that is with a cat, resonator and muffler bolted back on... so just get a proper cat and do everyone a favour
kinda sounds like you were going to gut your cat no matter what these guys have said? :S
the gutted cats iv heard sound hollow n a bad sound as if they have big exhuast leaks...
CJ
ps, i must be a lazy cu*t, i sit in maccas drivethrough for 1hr!! (yeh right)
Ive got a black car so it won't look that different. It will fit you just have to cut the cat housing a bit. As for cancer and contributing to the death of the environment.. you guys are funny.
I think it evens out for me acually, i ride to work and catch the train to uni so i only drive my rig on the weekends which is alot better for the environment. The lazy cu*ts who drive everywhere and would rather sit for 1hr in macas drive through than walk into the place and be in and out in 5 mins are the ones you guys should be angry at.
cheers.
  • 3 weeks later...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
