I have just pursched myself a 95 R33 gtst with the following mods, FMIC, full 3 inch exhaust from the turbo, air filter, and a HKS boost controller. I have talked to alot of people about up grading the turbo, but they seem to tell me different things and now I do not know what to do. Do l highflow the existing turbo? or opt for something big such as a T04 with a custum manifold? and who in Melbourne is the best place to talk about turbo upgrades. My aim is to get the car to run in the 12 second bracket.
https://www.sau.com.au/forums/topic/14387-turbo-upgrade/
Hi-flow std turbo.
full engine management
550cc injectors
fuel pump
fuel regulator
and most importantly, a GOOD TUNE!
Optional: ADJ. ex. cam gear
These mods, along with good tyres will definately get you into the 12sec bracket. It will also improve on the drivablity of the car.
Alan C.
https://www.sau.com.au/forums/topic/14387-turbo-upgrade/#findComment-290559
Try GCG turbochargers. They do hi flows or full upgrades. Its my understanding that you wont need to go really big with the turbo and custom manifolds etc, and you'll have 12's potential with a high flowed unit.
from GCG:-
The factory turbocharger is a ball bearing T3 sized unit with a ceramic turbine wheel. In upgrading this unit we replace the ball bearing pack with a new one while replacing the turbine wheel and compressor wheel with hi-flowed models. The upgrade comes in two stages.
XTRGTST-STG1 450hp rated $2250.00
XTRGTST-STG2 500hp rated $2450.00
These conversions are do to the existing unit only.
http://www.gcg.com.au/home.htm
hope this helps. Im considering STG2 myself, anyone got one of these?
btw, you dont HAVE to get 550cc injectors. This expensive mod can be bypassed by just a rising rate regulator (whatsisname: 257rwkw with std injectors. A high flow might net you 235rwkw??). Def. need the management.
https://www.sau.com.au/forums/topic/14387-turbo-upgrade/#findComment-290571
Sly33
How lean is the a/f mixtures to acheive ~260rwkw. Just remember that an engine makes more power when it is running lean, but how long will it last b4 something blows?
I have a Wolf 3D plug-in on my car and it is making 190rwkw with the a/f mixtures at ~12.2 and the std injectors have a duty cycle of 88% at full load (std fuel system, soon to be upgraded).
-How much rwkw can a rising rate regulator give you and still have a safe a/f mixture? (5-10rwkw?)
-When you say a 'rising rate reg.' is it the same as a 'fuel reg.', or are there two different types of regulators?
https://www.sau.com.au/forums/topic/14387-turbo-upgrade/#findComment-290594
Thanks guys for the replys. I have looked at gcg website, but they do not list a distributer in Melbourne. SLY 33 do you know what size wheels are used in the stage 2 upgrade? I have been to ATP and was quoted $1500 for a high flow turbo. The owner, Kyp was telling me his brother has a GTST, they high flowed the turbo, match ported the standard manifold, fitted a 3 inch exhaust, FMIC, fuel pump and reg, kept the standard injectors, a wolf 3D and got 200RWKW and pulled a flat 13 at calder park with street tyres at 107MPH. Looking at the MPH wolud that indicate a high 12 pass with good traction? As for a computer, l am tossing up between a Wolf 3D and Apexi Power FC. The Wolf is alot cheaper, but l have heard it cannot support bigger injectors, is this true?
https://www.sau.com.au/forums/topic/14387-turbo-upgrade/#findComment-290697
Hey bodge,
That ATP turbo isn't all that fab then next to the stocker.
I got a 13.3 @ 106mph with the stock turbo on cheap'o 205's. My S-afc isn't properly tuned either. The MPH would be a tad higher if not for a self imposed 6000rpm redline to avoid a knock above that rev.12's are on the cards soon. BTW thats a full weight car + all my work stuff.
Mt point is if you want 12's then you don't need too much more than the stock size turbo. Then again you will need something to match that big intercooler you have.
https://www.sau.com.au/forums/topic/14387-turbo-upgrade/#findComment-290786
Originally posted by Al
Sly33
Al,
Attached below are the A/FR's on my current tune (WOT of course). As you can see from the dyno sheet a reduction in fuel (throughout the whole rev range) shows we still some fuel left in reserve. The biggest limiting factor is the amount of boost. Over 17psi will regisiter "max duty" on the Microtech.
I still use factory injectors, a bosch '044 pump & rising rate reg (~65-70psi fuel pressure on boost) I could push pressure even higher but I'd rather what till internals are done & bigger injectors go in.
Japanese factory injectors are very good at handling high f/pressure. As much as 90psi has been pushed through stock injectors without failure (long term)! If the remaining fuel system is up to the task then no prob's :P
Just look at the Nismo 550cc'ers that Gibson Motorsport used in the ATCC R32 GT-R's. Up to 128psi f/pressure! Big Bosch pumps, twin fuel systems & a mechanical pump gave the total fuel system plenty of ability to cope with the demand 128psi would need! Nismo 550's obviously use good solenoids.
A variable rising rate reg (VRRR) is just that. It allows a base variable adjustment plus a greater than 1:1 increase ratio (i.e 1.7:1 - every 1psi boost gives 1.7psi f/pressure increase).
A standard reg will give a 1:1 rate.
Large HP goals - no better way to go about it than larger correctly sized injectors.
Medium HP increase - a good pump & VRRR is not a total "band aid" appoach. If applied correctly.
https://www.sau.com.au/forums/topic/14387-turbo-upgrade/#findComment-291036
thats a better answer than i could give!
I agree about the GCG stuff, it does seem expensive, for the price you can get a good condition HKS2530 or similar...
As for ATP's $1500 high flow turbo, and 200kw at the wheels, I have this with my standard turbo, and id expect low 13 sec qtr's as well. What other mods did the car haev? it must be lacking something, as its only making standard turbo power!!
https://www.sau.com.au/forums/topic/14387-turbo-upgrade/#findComment-291158
SLY33,
As always the dyno figures don't mean anything, all dyno sheets are good for is an emergency toilet paper substitute. I don't consider the standard turbo capable of helping the RB25 to anything much over 300HP at the engine. You should go see how your car goes at the 1/4 too it's alot of fun and I think we need as many gtst's as we can get doing some good times.
To be fair it's possible there are other tuning issues with the ATP example car. To do a flat 13 in a gtst is impressive but, the mph indicates a problem somewhere. perhaps the owner shifts gears like nanna?
https://www.sau.com.au/forums/topic/14387-turbo-upgrade/#findComment-291187
Sly 33, The mods that l listed in my previous post is all that was done to the ATP car. l guess looking at the RWKW figure, its not that high, considering some people are pulling that sort of power with a standard turbo. Prehaps his running low boost to achieve this figure? l will try and find out, but the guy is very hard to talk to, seems like a bit of a Muzza to me.
https://www.sau.com.au/forums/topic/14387-turbo-upgrade/#findComment-291790
bodge,
the flat 13 speaks for itself. Don't worry yourself or others over the rwkw figure. Like I said its as good as toilet paper (only fit to wipe your ass on).
There are quite a few 200rwkw claims made about stock turbo's and I'm yet to see even one come good on it at the strip. I've seen a few dyno readouts that have shown 300rwhp even both cars I have made look slow in races. I'll give you the tip -- my car doesn't have much more than 200kw at the engine lets say 280hp tops. Before people start the winge ' but the standard engine has 184kw blah blah blah... ' remember that these engines we have now are far from fresh having done close to 100,000kms in my case (they don't make anywhere near stock hp at that vintage).
The ATP car is basically to date is faster than any stock turbo'd gtst I know of including mine. Bottom line is " TALK IS CHEAP " so until I knock off the flat 13 it did ATP's turbo is an upgrade (if not a big one).
https://www.sau.com.au/forums/topic/14387-turbo-upgrade/#findComment-292037
Can't say as I agree with this statement Dave.
What about A/FR's, boost response curve, power & torque curves under WOT, comparing before/after power & torque gains & so on... Sure, these things "can" be done in other ways (on road, datalogger) but the dyno is a far safer & repeatable environment, that doesn't cost that much to use & doesn't require a large outlay for the average Joe.
I do agree that a dyno sheet on its own, used to "prove" xyz car has xxxrwkw, isn't worth much, unless you like to compete in dyno shootouts. Nothing wrong with a friendly dyno shootout :P Can't be all that bad if the mainstream Summernats HP Hero's get a kick outta' it :D
Oh yeah! The biggest reason I disagree with you mate? A4 paper is far too rough on the arse cheeks. So I’m told :P
Matt
https://www.sau.com.au/forums/topic/14387-turbo-upgrade/#findComment-292614
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
