http://www.worldcarfans.com/tuners.cfm/cou...ore-information
Don't know if you are into porsches, but I can't stop drooling over this thing!
It was said that Nissan is bench marking the new GTR against the 997 turbo, although this one is a bit more extreme than the standard one, it should give you some ideas of how good the new GTR need to be.
Heres some stats:Displacement 3,600 cm³
Bore x stroke 100 x 76.4 mm
Max. power 580 hp / 427 kW at 6,000 rpm
Max. torque 700 Nm at 4,850 rpm (from 3,200 – 6,000 rpm permanently more than 670 Nm)
Max. boost 1.2 bar
Max. revs 7,100 rpm
Power output per liter 161.11 hp per liter capacity
and what do you think of the colour? white is the new black?
Edited by Forged
  • Replies 40
what black then?
if you look at the current german aftermarket tunning scene, every major tuners all seem to have a few white colour based project cars, whereas a couple of year ago black or silver was THE colour.
i must say i do like it. i like a lot of new cars in white. like the mazda 6 and the ba/bf xr's. just something about them that looks racey. like a mines gtr.
and pfft, its not that quick. my mates fully sick stock as a rock 3 speed auto 1977 chrysler galant thats only running on 3 cylinders could beat it...... if they were both dropped of a cliff.
can't compare the new GTR to this... because this is an after market tuned 997.
Compare a Nismo tuned GTR to this porsche.
yes true, a nismo GTR or mines GTR would be a better comparison. but there are much similarities between the 997 Turbo and new GTR. 3.6l flat six versus (rumoured) 3.6-3.8 V six, both rev to about 7000rpm as opposed to previous GTRs higher rew limiter, weight is not dissimilar either at 1600kg give or take, and of course twin turbo and 4wd.
Edited by Forged
pfffffffffffffffffffffffffffffft - my 1982 honda civic will destroy that thing..............................
for like 0.02 seconds before the driver of that porsche realises that im racing him....
was only using Nismo as an example.
I believe the Mines R34 GTR was around the 650hp?? I reckon it would be a decent match for this Porsche
Thought Best Motoring had a similar test in the past (911 turbo vs tuned GTR) Any idea how much a Mines GTR costs? Not 200,000 euros I'm sure!
And was certainly a good point! Was just expanding on it. :nyaanyaa:
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
