Thought Best Motoring had a similar test in the past (911 turbo vs tuned GTR) Any idea how much a Mines GTR costs? Not 200,000 euros I'm sure!
I've heard AUS200k, but don't know for sure.
The Techart 997 is a beautiful car!
If you want to compare a factory car to a factory car then compare the new GT-R to this: http://www.ruf-automobile.de/content.php?s...=&details=1
  • Replies 40
I belive that ruff is an aftermarket tuner so that would mean that comparing that car to a standard nissan GTR would not really be a fair comparison.
Incorrect, Ruf is actually an independent car maker who builds complete new cars from bare chassis(based on Porsches).
RUF Automobile GmbH is a producer of high-performance vehicles, specializing in manufacturing new RUF automobiles completely from the bare chassis, conversions to RUF specification and the performance enhancement / refinement of Porsche cars.
Unlike TechArt, speedArt or Hamann, they are aftermarket tunners for Porsche cars.
RUF sells complete new cars with warranty, like these:http://www.ruf-automobile.de/content.php?seite=seiten/modelle_neuwagen.php
Edited by Forged
I do like this porsche, what are its specs?
The body modifications looks more integrated than the TechArt 997, which looks more like add-ons if you know what i mean.
im much more into the hamann porsche really
hardcore volvo
As said above RUF is an independent manufacturer, not an aftermarket tuner despite them selling aftermarket parts.
The Hamann 997 is very nice, I'm a big fan.
200K euro = $334k AUS.
This Mines built R34 actually sold for less than $150k recently I believe?
http://autostyleprestige.carpoint.ninemsn....styleprestigeau
dunno how much it sold for, is over east (the one that everyone knows that scared the shit outta those japanese rivers) but it was in autosalon a while back and mines had spent over $300k on it.
there ya go :P
ive driven a 997 turbo
they dont drive like a turbo and are progressive in the way they make power
i booted it through 1st 2nd and 3rd looked down a realised i was doing 199km/h
its gets there so smooth and doesnt feel like ur doing those speeds
best way to descibe it is it feels like a fast n/a car
its not that they r tiny
they have are useing veriable pitch on the turbine blades
coz a tiny turbo will chock the top end and believe me there was no chocking in the top end
also as an interesting point there r no waste gates in a 997 turbo at all
Interesting how 334k AUD would only buy you a standard 911 turbo in Australia!
actually... you can get a brand spankin GT3 RS for a smidgen under $300k i believe.
yeah but the turbo is more expensive then the gt3
and there will only be 25 gt3 rs's in aus and they arnt in the country yet but there all sold
yeah these variable geometry turbos use a set of vanes in the exhaust housing to maintain a constant gas speed across the turbine, and the vanes are controlled by a membrane identical to the one on a wastegate so no wastegates needed.
this is also the reason for they have minimal lag not because they are small.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
