I use motul, seems lots of import users use that, ppl say its better then shell helix, bloody expensive though but worth it for ur baby :P fully synthetic of course. i think the rating is 5w40 or sumthin. so it starts easy and remains the same throughout the rev range. its doin well cos i was on the track yesterday doin laps and the only thing that overheated in my car was the CAT, i think i destroyed the stuff inside it which means POLLUTION (oh well) :P
Clint-O
Motul 8100 Synth - $55 from Autobarn (UAS wanted 65)
NGK Iridium Sparks - $13.50 each
Ryco Fuel Filter
Ryco Oil Filter - $9
Nulon Radiator Fluid *Make sure you definately check your coolant levels*
My car seems to run better milage with the ryco filter, and the oil holds better, prolly due to oil quality, UAS said the genuine nissan oil filters are better and arnt that much more expensive ~$13
Try and get a 100% synth oil no matter what, they warm up quicker and can move more freely around the vital areas.
  • 4 months later...
back from the dead...
so we've established that a fully synthetic oil should be used, but what weight/thickness should be used? i believe it should be heavier/thicker than the oil in a RB25DET, which people on this forum generally agree should be 5w40, but i can't find any info on the RB25DE.
i've just done my first 5000kms so i need to change pretty soon.
has anyone got a workshop manual that states what oil nissan recommends?
Cheers,
Greg
Guest RedLineGTR
5w-40w
the 5w is the thickness of when the car is cold and starts up..so having a thick old for startup dosent really help at all to lubricate the engine when its cold and causes more wear on startup from cold. the 40w rating is the highest temp or how thin it can get and the high temps.
The only oils i would consider is 5w-40w maybe 5w-50w...10-40w and maybe 5w-30w also...nissan dealers have the original oil which is 7.5-30w which has a nice gtr logo on it.
thanks for explaining it all, i had a vague kind of idea that the numbers were idicating viscosity but didnt really know what that meant :D
the mobil site recommended Mobil 1 5W-50 for an RB30 (they didn't have RB25) and that sounds about right from what you and others have said. i'll look into the motul because a lot of people seem to be using it. me being a tightarse, it will probably come down to price when deciding between mobil1 and motul. anyway thanks for your help.
cheers
greg
ive just put shell helix ultra 5w-40, ive made out in the maual that they reccomend 7w-40, sumthing not very common in auto shops here! im thinking of putting 10w 40 in next time just to see if there are any differences. i thinking opf using mobil R next time round, its what they use in dads M3
Originally posted by Greg
hi all,
I'm about to do my first oil change since compliance and since i don't have an owner's manual i was wondering if someone out there would be kind enough to post up what type of oil i should be using (ie weight etc). Is it the same as the RB25DET?
Thanks,
Greg
Where can you get the owner's manual from anyway? I really need one of these ey.
Cheers.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
