herro
im not one for racing but could not resist seeing what the new rb20de cef does compared to what im used to with my old rb20det one...
bad idea
owned by a mildly modded rb20det r31 which even worse had custom plates with the owners name...
this cannot happen and i appologise to all cef dawg owners...
engine out of the blue one is gonna go into the black one next weekend ive decided and ill sell the blue one with rb20de...
my question... loom swap... i wanna put 32 loom in as its a 32 20 with half cut a31 half cut r32 loom bits in it... just want a fresh hassle free full 32 loom to go in...
straight forward rip out and put in? use 32 comp and everything... im assuming so but thought i would ask!
told the mrs tonite - next weekend is dedicated cef weekend
engine out of the blue one and tidy blue one up
black one gets the pink bits cradle with 32 5stud hubs, r33 twin pots and kaaz 2way + solid cradle spacers and gtr sway bar
then weekend after - turbo engine can go in
https://www.sau.com.au/forums/topic/143917-a31r32-loom-swap-qs/
ADZ, if changing looms, you may need to change everything else to suit. i know that cefiro has 'square' style connectors (eg z32 afm fits straight in with same pinouts!) and 32 has round ones....
this may be a problem with all your other connections for water temp sender etc... i know coilpacks are ok, and inj are ok, but at the other end where they go into ignitor pack are no good.
so unless you have got all the bits, i wouldnt bother.
On another note i've had 2 different 32 remaps working in my car before, they were just not a suitable map (one was kelly's and other was a donnon one).
yeah way i see it huddymonster
i have an r32 rb20det... so if i use full r32 rb20det engine harness all wires should be fine... my only problem would be connecting to the chassis loom (dash cluster etc) which may require few wires to be cut?
agreed?
$350 aint that expensive. )) Some koom conversions are much more expensive )).
Anyway what I wanted to ask is, if any of you guys know if the procedure will be similiar to this if the base car is rb24s ceffy (carb one). It doesn't have an ecu and fuel pump is retarded and bucn of other 19th centurey crap LOL.
Edited by robots
