Which is the best and recommended ECU for an R33 GTSt automatic? Can go piggy back or stand alone just need to know which one? I have been told that Apex-i Pfc cannot be used on an automatic without tinkering with the unit. Has anyone who owns an automatic come across this issue? Also do i need to have my engine/ stock ECU tuned after having fitted an FMIC, Airfilter and EBC (boosted to 10.5psi) + iridium plugs set to .8mm? (Tuning as in DYNO?)
https://www.sau.com.au/forums/topic/143924-ecu-for-r33-gtst-automatic/
If your looking at spending more money down the track on more mods to make the car go faster, then go straight for a PFC.
All the hype about it not working well with the standard auto is well exagerated. I have owned a s1 r33 sedan now for a couple of years, it spent 12 months in the 220 - 270 kw range and now its up into the 320rwkw area and i still cant fault the auto.
My box has a mv shift kit and a large trans cooler but thats it.
as a precautionary messure my car is going in on the 7th dec for the full race trans build by MV autos, which will be somewhere around the $2500 - $3000 mark including hi stall, etc.
when you compare how much guys making this sort of power spend on a decent clutch etc i think the 33 auto's are sold well short of what there capable of.
anyone that coments on here against what i have just said, has never been in a r33 auto with a shift kit.
Cubes can vouch for the shift quality, so argue with him.
Sorry Joel but i need someone to back up my claims.
Or ask 4doorsleeper.
Cheers :wave:
im surprised
cos when you nail it
the engine is on full load and throttle
as you gearchange the throttle doesnt close
so afm voltage is constant, which would mean it wont move around on the load map, well it would a bit, bit not to row 0 where you could back out timing
im just surprised it doesnt, can u get me a map tracer of a run from say a low speed to a high speed, say 20km/h to 80km/h ?
im surprised
i will see if i can get a trace file from my dyno operator.
but i think i have proved the strength of the box, and that it works dont you?
a few have said many times it will work as far a drive
and run the car, im just surprised it isnt detonating on gear change
or that you arent seeing other strange issues
how is the timing on the tune?
how does the dyno chart look like? how is your average power?
i entered my dyno sheet into the xl spreadsheet thing thats just started last week so have a look on there and compare it to your xr6 etc.
The facts are that the standard ECU retards/cuts the igntion on gearchanges. This makes the changes smooth and stops full load on the gearbox (bands and clutches) during the geashift. Aftermarket ECu's don't have the complex mapping for this retard/cut. So you get rough gearchanges and premature gearbox wear.
These are the questions that I have asked the other 6 guys who swore that they had no problems with their auto and an aftermarket ECU.
1. How smooth is the gearshift on a full throttle up change?
2. How smooth is the gearshift on a low throttle upchange?
3. How would you compare the gearshift smoothness to when you had a standard ECU?
5. How many K's does it travel?
6. City traffic?
7. Circuit work?
8. Drags?
The answers might help you decide whether an aftermarket ECU will do the job to your satisfaction (one man's meat is another man's poison).
:wave: cheers :blink:
6. City traffic?
7. Circuit work?
8. Drags?
Hi Gary
i hoped you would enter into this discussion.
the car is a daily driver and is normally driven by my wife.
as the car has a stage 2 shift kit, the shifts are quick and precise whether it had the stock ecu or the PFC.
as far as shift points are concerned it does everytyhing when it should acording to your right foot.
its very predictable and is the same quality of drive today as it was when i installed it.
The shift quality compared to the standard ecu cant be measured as the stage 2 shift kit does all the work and shift quality is the same regardless of ecu.
i agree without the shift kit a aftermarket ecu would place more stress on the bands etc, but with a shift kit the ecu issue is removed.
thanks ill have a look, the xr6 isnt mine, a friends.
just had a look, wierd that the power goes down at the start, is that a gearchange?
can u show us the actual dyno sheet ?
No gearchange i have unplugged the trans loom in the engine bay so the car is stuck in 3rd
as the car takes off in third it may just be how John used the throttle to get the rollers up to speed.
As you can see boost ramps up ridiculisly fast and the trans is still going strong.
what happens if you leave the loom connected?
why was it removed ?
if you leave the loom conected it can try to kick back to 2nd when you give it WOT in Drive!
or you have to do the run with it stuck in second.
but much past 250kws it will ramp up to fast in second and smoke the tyres.
by unpluging the loom you solve these two probs and can tune all the map not just WOT.
I visited a shop and inquired about an Apex-i PFC, according to them there isnt a unit that suits my car. So we then had a look for another brand a GREDDY stand alone but apparently this unit was also incompatible for my car, it being automatic. So now they are suggesting that the only unit i can fit in my car is a GREDDY E Manage. ( Piggy Back!) My Reply was "ahh uhmm No Thankz! Maybe Later." I want a Stand alone unit as i will be chasing more HP down the drack. Still my dillema is finding the most suitable unit for my GTSt Automatic S1. According to many Apex-i is the best selling unit in the market and that is why im keen on em. Just need to know if it is possible to chuck one in an Automatic. Im from Adelaide do any of you guys know any good mechanic from down here? A fellow from a Nissan dealer suggested WILLALL RACING, i've read some tech stuff from magazine and they have been mentioned a few times.
Being an auto r33 gts-t owner myself, i have asked myself the very same qn you're asking yourself now a few weeks ago. After quite an extensive amount of reading up and asking around, i have found out that:
If your car is an auto, it's best that you keep your stock ECU unless you want to trash your transmission, or do a manual conversion. No exceptions.
Piggy back systems are the only way out for us, and seeing that the PFC is already discontinued, i would seriously recommend that you get Apexi's new product, the P-NBC, rather than go for something obsolete.
Details: http://www.apexera.co.jp/carlife/pro_apexi...ics/P-NBC1.html
In case you can't read japanese, it supposedly takes the advantages of the AFC and PFC and places it into one product.
By the way, if you're going to go for an AFC, the SAFC2 by apex'i is also a discontinued product. Go for the AFC Neo instead.
I fitted my car with an AFC Neo and an RSM a few days before i found out that the P-NBC is released... *sigh*
Are you serious?
havent you read what i have typed above..
you must be drunk....
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam camp bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
