Following on from this thread in General Maintenance
http://www.skylinesaustralia.com/forums/in...&hl=window*
My drivers side power window has been playing up for ages and I have been trying to find the root of the problem. It would work most times, then all of a sudden just stop working. If I bashed the door handle and switch surround a couple of times it would sometimes start working again, but also sometimes not. Then it would work again for no apparent reason.
First I thought it was the switch mechanism, so I pulled it apart a couple of times and checked everything, and re-soldered anything that looked dodgy but it never fixed the problem.
I found the culprit to be the relay/switch (mentioned in the thread above)for the auto power window. If I moved the plug connected to the relay around a bit it would start working again. Interestingly though, there was always a ticking coming from the box when you used the window switch, whether it was working or not.
I didn't really have time to look at it properly when I first discovered it, so I cable tied the plug in a position where there was obviously a decent enough contact to get the windows working, and left it at that.
That fix was all working fine for a few months, but the other day I got stuck with the window down and it wasn't going up for love or money, so I was forced to take action.
I have taken some pics that may help others (the quality is crap)...this was the procedure:
Remove door trim -
- FIRST! remove the plastic cap in the armrest well and undo the screw located underneath, that is if it hasn't already been destroyed by some other monkey, in which case there will be a gaping hole where the plastic mount point used to be, so skip this step. Mine came broken :)
- Then, remove the plastic surround containing the window controls - there is a plastic clip underneath the centre of the surround holding it down so just lift from the outer edges in the middle until it pops out.
- Next, remove the surround from the door lever/lock mechanism as outlined in the pic
- Then, remove the three screws at the bottom of the trim as indicated in the pic and pop the push clips out on either side of the door. Then remove the door trim by lifting out and up from the bottom.
Locate and remove relay -
- Locate the relay to the right of the handle. Remove the plug and two screws holding it in place
Dis-assemble and repair relay -
- Lever the end off the relay with a small screwdriver or other weapon of choice. Pic shows lever points :P note the care and patience taken :D
- The relay PCB is just sitting in there on some plastic runners and slides out easily. Remove and check all the soldier joints on the back for anything suspect looking. Mine was pretty obvoius as shown in the pic below
- Re-solder anything that looks dodgy. BEFORE you put it all back together, plug it back in to the loom, connect your window switches and make sure it works. If so, re-assemble the relay and put everything back on in reverse. If it's still not working :laugh: set the car on fire and call the insurance Co. ;)
Edited by Lazy-Bastard
Hi.
I have a simular problem with the drivers side window.
What I found was a variety of problems.
Located the relay controller and resoldered 5 or so fractured solderjoints.
Just for the record, a fractured solderjoint is a fracture around a leg typically associated with mechanical vibration.
I am only saying this to make people aware that the fracture appears as a hairline crack, sometimes hard to see around typically the 2 relays as in my case.
Resoldered all connections to both relays.
Needless to say, the window failed to operate. (stuck in the raised position)
Next approach was to locate the power wires to the actual motor, seperate the plug and apply power directly to the motor.
The motor "ticked" and got hot.
This could indicate 2 problems.
1) motor stuffed and/or 2) regulator mechanism jammed.
My problem at this time is to remove the window regulator which requires the window to be in the lower position.
No motor, no operation. Pain in the butt.
Before I attempt this repair, I will want a replacement motor in hand because if i'm going to all this trouble, I will fix/replace it before reassembly.
Now, does anybody know where I can get a motor only. I don't want to purchase a complete regulator assembly.
Pending on price, the motor can be rebuilt and rewired which I will look into once I have it out of the car.
James
  • 2 months later...
  • 4 weeks later...
my window didn't work when the car was purchased.. i resoldered a few joints which fixed the problem.. a few weeks ago it stopped working again so I noticed a few more dodgy solders.. (probably mine).. i fixed these but recently i have noticed i have to hold the switch for a few seconds and press a few times before the window will go up.. going down is fine but up was delayed...
today when the window was about 1/3 of the way up it got really sluggish and stopped.. it went back down i tried again and it got stuck again.. now its stuck in the down position. I checked the solders, this time they seem fine so I'm thinking its the motor..
does anyone know if the relay contacts move, would this indicate that the relay is fine and its the motor? or can the contacts move and still be the cause of the problem?
cheers!
cheers!
The relay should work regardless of the dodgy soldering in the black box. I can hear my relay tick over and the window does not work due to those bad soldering points. As for it getting slow and stuck, your motor is either on its way out, OR you need to apply some dry lube to the runners to stop the friction. Otherwise if you keep it the way it is the motor will eventually burn out anyway.
Can you hear a clicking noise when you push the window button? The clicking noise is the sound of the relay closing, if you can hear that then the relay should be OK.
The way the you described the window motion as being sluggish leads me to believe that the motor has burned out. If it was the relay I think it would have simply stopped and not slowed first.
yeh thanks..thats what i was thinking.. i have the relay taken out of the box and when i move the button i can see the contacts are moving up and down so i guess they are fine.
any ideas how to get the window up so i can use the car? seems impossible to manually move it..
Sorry mate, never had to do it before...
It should become clear once you attempt to get the burned motor out.
It might be the case that your motor actually burned out due to the window pane ceasing in the runners. Which would explain why you cant manually move it
  • 4 months later...
:rolleyes::):)
Thanks for the info, my window would work one moment and not the next. could give it a thump sometimes and then it would work for a while.
anyway, had two dry spots at the back of the PCB, who knew lerning to mod x-boxs would come in handy. so solderd them and away it went.
  • 3 weeks later...
Oh i need to mention that clicking noise if its stuck in the down position is the actual window motor burning out as i found out the hard way so carefull of that esp when the relay is playing tricks :P cheers
  • 9 months later...
This is gold!! I went 10 months with an on/off window which then was just off (thankfully up!) and after reading this I spent just half hour getting the relay out and soldering it and BAM!! I have my window back! Nice one dude
  • 1 month later...
yeaha my power window motor seems to be gone i can hear the relay but the motor was maing a loud eeeeeeeeeeeeeeeeerrrrrrrrrrrrrrrrrrrrr sound, but that has now stopped i guessing it burnt out...hmph
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
