hi guys
anyone know if there is an aftermaket plenum to suit an r34gtt? im after one with a front facing throttle body.?
why dont the ones for r33 fit r34neo engines? is it only because of the fuel rail? what other mods would need to be done if any?
thanks
Justin
https://www.sau.com.au/forums/topic/144004-aftermarket-plenum-to-suit-r34/
They don't bolt up to the head. Completely different.
I have heard of an R33 one fitting with some new holes drilled into the head and some on the plenum but haven't seen it.
You could get a custom one for the top half only made up fairly easily.
There has been talk of a couple being available soon but soon just keeps stretching out into infinity.
Are you 100% sure, i havnt tried it, but only as i havnt had the parts at the same time, i am pretty sure they are the same bolt pattern, The injectors and fuel fail mounts are different.
OK now the greddy r33 plenum does fit the r34.. lets put that to bed now i have one on my car and no problems..
hey guys
1
im not saying anyone is wrong or wright here, (as i have no proof and havent tried this yet) but i find it hard to beleave nissan would change the bolt pattern on r34 to be differrent from r33, so can anyone 100% confirm the pattern is different or is it just what ppl have been told?
2
is the top half of the plenum the same pattern as r33?
3
IF IF IF the patterns are the same, all that would need to be changed are the fuel rail+injectors?
4
Mario, More info please!!!!!!! i know it sounds like a stupid question but are you 100% sure your engine is a Neo? if it is we know a greddy plenum will fit! please give us more info and photos.....i want a greddy plenum soooo bad so i can tidy up my engine bay.
so can anyone give a 100%confirmed answer for the top 2 answers?
thanks
Justin
theres a guy on the forum user name: 600hp who makes custom plenums for R34 GTT. very good quality and price, flow more/better than most jap name brands I was told. just send him a pm. cheers
Edited by Forged
you could always cough up the money for a RIPS plenum...but the greddy one does fit, you'll have to use the r33 iac and fuel rails iirc.
so the patern is the same and the greddy plenum will fit yaaaaa...
i hate to sound dumb or ignorant,(but i am a simple deisel mechanic) can someone post up a pics of the r33 IAC (idle air control valve) and an r34 one?
what about the traction control throttle body?
i would like to set up a Q45 throttle body is it easy to set up? eg electrical plug, how to set up tps?
thanks
Justin
Edited by walkoau
This 600HP plenum; does it retain all the R34 bits like fuel rail and injectors? Got a photo?
i believe itis compatible with the factory fuel system, with larger throttle body too. best to pm the guy.
cheers
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
