guys,
im confused with after market BOV, i mean std one for R32 is plum back, so if i swap for atmo one and block the plum back...is that bad for the turbo? because people tell me that it ruins your turbo or something....confused me BADLY@@!@
any help would be great!!
THANKS guys
https://www.sau.com.au/forums/topic/144035-is-blocking-the-std-plumback-bad/
You're confusing two things for one. You either swap your stock plumb back BOV for an ATMO one or you BLOCK the standard one. They generally both screw up your AFM readings resulting in backfire, stalling issues, idle issues.
I've blocked the stock BOV and the only thing I've noticed is that perhaps my fuel economy has gone down abit and that I get the occasional loud pop (backfire) on gearchanges. No stalling or idle issues.
ok well....im talking bout removing the std BOV and installing atmo one and blocking of that pipe....LOL no idea wats its called... i mean i swaped it over....car was fine for a bit...then the thing i used to block the pipe started leaking and then the car began stalling and shitting itself...
so i put std bov on again and yer fine....
so i dunno wat to do...i luv the sound of aftermarket bov though. atmo one that is
Ahh I understand, you fitted the BOV and blocked the recirculation pipe. Just make sure the bung used to block the pipe is on tight with a hose clamp. If you have problems regarding idle its most like your BOV is leaking.
Run a MAP sensor... no stalling or idle issues at all :happy:
Coke Cap = BAD - I had this in there for a day before I got the Turbosmart plug (billet) and it melted; I'm lucky that the temps did not get hot enough to turn it into a liquid and run down the recirc pipe.
IMO; if you must use DIY bungs, the end of a broom stick is better!
FLUTTER ON BRO....
waa? I don't know any one who has one with a BOV :) I meant any r32 model, btw.. All have the outlet on the inlet piping but all were blocked with rubber grommets.. Not to mention everything i've read on this site seems to suggest rb20's were BOV-less :woot:
Do you actually know anyone with an R32? The outlet on the inlet you speak of is actually the inlet for the plumback piping from the standard bov which is located on the standard crossover pipe..
Now I am questioning whether you can actually read at all :)
Beer Bottle Caps as Bungs FTW! Used two for a long time, no dramas. Also if you are smart, you put the question facing outward, then you have a little bit of trivia to keep you company each time you open the bonnet.
No, not kidding. Have pics of setup.
Well i know 3 people with them and all of the BOV outlets are bunged up (well the outlets from the plumb??). I thought r32 gts-t and below were all BOV-less.. I've never really looked into BOV's and consequently know very little (so no need to go hack). To me, in most respects, they appeared quite superfluous, but if 32 gts-t's have them from standard i'd be interested in putting one on. Any pics of this crossover pipe? Or of the positioning of the BOV?
Edited by 123456
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
