hey, i have a R32 gtst type M! The mods are apexi pod filter and and 3" cat back exhaust (i dont know this for sure though when look under car it is obvious that from the cat back the exhaust is larger then cat to turbo!) I just installed a boost gauge and it is reading 10-11PSI in all gears and holds this! My car does not have a boost controller! Is this boost right as i thought it was a bit high! Do type M run a bigger turbo or more boost? Any help would be great!
Cheers,
Tyson
https://www.sau.com.au/forums/topic/144046-32-boost-doesnt-seem-to-be-right/
thanks mate, did some searching though eveyone has there own say on 32 boost.....it stock 7PSI....stock 10PSI
One more questions: I have done heaps search on 32 boost and need some advice! I am going to get the rest of my exhaust done so (dump and front and high flow cat) so it will be a full 3" system...the car will prob run about 11PSI then! Should i get a boost controller and up the boost to 12PSI - dont want to go any higher than this, and get a front mount! or buy a 33 or 34 turbo to get more boost?
Cheers
Upping it to 12 won't hurt but the standard turbo gets boring pretty quickly, so buy a cheap boost controller, and crank the psi to 12 after you've put the exhaust on, and run around on that while you save for a better turbo. Standard rb20 turbo @ 12 psi is preeety boring
Yep 12psi is pretty boaring through the rb20's.
I pushed mine to 1bar without issues for a few years before the new motor was dropped in. Old motor was 100% still fine as was the turbo when it came out.
wat mods did you have when you ran it on 1 bar? did you still have stock internals?
also on the stock boost gague in a r32 gtst type-m, the -7 and +7 on the boost gague
does that refur to psi or does +7 mean 0.7 bar or 7pi pr wat? if thry run 10psi stock, why does
the gague only go up to 7?
Edited by Josh_r32
The car just had a full exhaust, fmic and had boost wound up on the dyno. AFR's showed they were leaning out so a new fuel pump went in. It was then advanced 2 degree's and wasn't pinging on the dyno even though temps were 30degree's.
On the stock guage.. Mine was a little out, with the needle almost ready to topple over the +7 top line that was 15psi.
Have a look at the std guage it tells you the units of measurement used.
+7 is supposed to be around 13.5psi from memory. As I said mine was out a little.
thanks for all the replies! I have to agree, atm the stock rb20 turbo is boring! I will get my exhaust done and up the boost to 12 PSI Should i get an intercooelr after this? (will it give more power) or look at a 33 or 34 turbo?
im not an expert so im not 100% sur ebut i think any increase in boost should warrant a FMIC, even if it isnt totally needed it looks cool and is usefull if you want to go further later on, lots of ppl use turbos from 33's, stock or highflowed, never heard of anyone using from a 34 but dunno if u cant or what...would of thought it weas same turbo as 33, probably just more expensive...
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
    • So you had a car that by all accounts drove well and survived track days, and that was looking great after months of being stuck at a paint shop. Some might call that a finished project. But you decided this is not quite right. So now the car does not run anymore. And the engine doesn't fit anymore. And the body parts don't match anymore. But, this is progress somehow. Greg, I think your subconscious does not like you and does not want you to drive this car. (I know I know, this whole escalation was not intended, but man, what a rollercoaster)
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
