humm..what's with the tail lights?
If 'm not wrong in order to have gauges in front of his airbag, he'd have to remove the airbag altogether.... I was about to fit the gauges at that position
as well untill mechanics said it's not possible..
yelow black blue and pink..huum emo..
7 gauges + 1 taco..imagine the combinations
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
