R33, stock except for 3 inch turbo back mandrel exhaust, pod filter.
I found that i had a compliance 2.5" cat, so i figured it's restricting the system, and changed it to an xforce 3" highflow.
A quick rundown on my boost gauges. they're both splitfire. Gauge A runs off the factory nipple on the plenum and is mounted on my steering column. Gauge B runs off the hose going to the bov(was there when i got it), and sits in my glovebox for double checking stuff like this.
Before the new cat, Gauge B showed about 0.5psi above Gauge A. So boost was showing as 8.5psi on A, and 9psi on B.
After the new cat they show 9psi on A, and 8psi on B.
If they both went up or both went down, it'd make sense. but they've gone in opposite directions. wtf?
Firstly, someone re-assure me that there is no way the new cat is causing more restriction than the compliance cat (which was not gutted or damaged). ie. it was a sound move, and of benefit to the system, even though i couldve gone with a more expensive option like a 5inch big body catco, but i didnt.
Secondly...what is with the boost readings?
I've confused myself, and you, no doubt. If you've read thru this, congratulations, you're more patient than i am.
https://www.sau.com.au/forums/topic/144130-lets-see-you-answer-this-onegenius/
ambient temps both the same?
you werent taking one reading from a cold night
and the other form a hot day or something similar?
either way, if both gauges have taken two different readings contrary to each other... makes me wonder about how accurate they are
boost guages are not acurate at all, also length of vacuum hoses may make some difference aswell, and guages are only a guide not a real representation of what the hell is going on, if you wanted results dyno it then see how acurate the guages are, compared to dyno result of boost, plus dont forget the error that may be seen from reading at an angle, same as if passenger looks at your speedo from an angle it will look different to what it really is, same as if you go by your speedo guage then your stupid as 99.9% of them are in accurate.
My opinion on this
Not only saying that, how do you know there isnt the slightest leak in one of the vacuum to guage hoses??? :S
Edited by Devils_Advocate21
i understand that gauges arent accurate etc. and leaks can cuase bad readings.
but...the gauges were reading about 0.5psi apart, and now they're reading 1 psi apart in the opposite direction.
u see?
also, is it even possible that a highflow cat can cause more restriction than the standard cat?
even if it is the cheap xforce option i went with?
the readings were at the same time, so same temp.
had a passenger reading the one in the glove box.
So... took inital reading... fitted cat, went for a drive immediately after fitment and took another?
Thats weird.
The gauges should be accurate, that is if your not running 11ty billion meters of hose...
was your old cat stuffed? collapsed inside?
Thats weird.
no, i didnt explain that properly, or you misundertood :D
the readings before and after the cat were not taken on the same day.
what i meant was, the readings showing the difference between the gauges is taken at the same time. ie, i'm not going out, reading one gauge, then coming back in, swapping etc, then out for another reading.
but i'm still baffled as to how one gauge showed higher by 0.5psi, and now it's showing lower by 1psi.
if the gauge on my steering column is correct, then changing the cat netted me extra flow which resulted in ~0.5psi gain (i'm happy with that).
If the other gauge is correct, then changing the cat actually cost me flow, losing about 1psi (not so happy).
the standard cat looked to be fine inside. all mesh intact, no loose rattling, etc.
Where does the hose going to the BOV come from?
If it comes from the plenum, they usually do, then my guess is the BOV is leaking 1.5 psi.
:D cheers :)
:D cheers :)
hmmmmm, interesting. yes it's coming from the plenum.
why now though? why not before the cat? is it maybe an extra 1psi that did it?
it's a gfb hybrid bov (full plumback), and the spring is set to quite soft. would tightening the spring fix a leak?
if not, how do u fix a bov leak?
Have you tried swapping the vacuum lines to see if you get the same readings?
yeah i was going to replace the line to the gauge that reads low, and see if it was just that.
but i'd also like to know how to check/fix a bov leak.
will tightening the spring on the bov do anything for a leak?
so how do you check for, and fix a bov leak ? (gfb hybrid bov)
if there was a leak somewhere else, it would affect both gauges equally, correct ?
Check is easy, disconnect the vacuum hose from the BOV and block it off. Then compare the gauges. If the guages now read the same, then you know you have a leak. So check the hoses and the clamps between the BOV and the plenum, a 1.5 psi leak is easy to have and hard to find. If you can't find any leaks then it's the BOV, try tightening it.
:nyaanyaa: cheers :happy:
did you have the same person reading gauge b both times. and were they looking at it at the same angle. or maybe the person just rounded up, or the needle had flickered.
go for a drive and look at gauge a and have someone look at gauge b. then compare readings. then swap places and repeat. then you will be able to tell if it is how the other person is reading the gauge.
yeah, i thought of that. and i will get someone to video cam the gauge so i can check it myself afterwards. lol.
but all this heat in syd right now. not the best time to be pushing the skyline. might wait for a cooler day.
i might just change the hose from the plenum to the bov, and then see what the reading says.
what diameter is that hose anyway?
i put a new silicon hose on from the plenum to the bov, with a new T-piece just before the bov, running to gauge B. all very secure, i cant imagine there's any leaks in the line.
gauge B is still reading 1 psi lower. tonight is a cold night, so i got 10psi on A, and 9psi on B.
the bov itself is bolted up well.
what bothers me is that there might be a pressure leak somewhere, hence the readings.
will adjusting the spring on the bov, to a harder setting, make a difference?
any others ideas of what to try, or where to look?
no, i havent swapped the gauges over.
i guess i should try that. the reason i havent is that the drivers side gauge is a bitch to remove, and the hoses in the engine bay arent long enough to swap over. i might extend the hoses and try that next.
yeah damn it, wouldnt you know it, it was the gauge playing up.
swapped gauges around and the bov line showed 9psi, while my factory nipple showed 8psi (with gauge B).
so gauge B was giving a false reading.
i shouldve tried this first, but i didnt imagine the gauge would all of a sudden give a false reading, after reading consistently for so long.
anyways, let that be a lesson to me.
good news, there's no leak :D
thanks for the help :D
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
