R33, stock except for 3 inch turbo back mandrel exhaust, pod filter.
I found that i had a compliance 2.5" cat, so i figured it's restricting the system, and changed it to an xforce 3" highflow.
A quick rundown on my boost gauges. they're both splitfire. Gauge A runs off the factory nipple on the plenum and is mounted on my steering column. Gauge B runs off the hose going to the bov(was there when i got it), and sits in my glovebox for double checking stuff like this.
Before the new cat, Gauge B showed about 0.5psi above Gauge A. So boost was showing as 8.5psi on A, and 9psi on B.
After the new cat they show 9psi on A, and 8psi on B.
If they both went up or both went down, it'd make sense. but they've gone in opposite directions. wtf?
Firstly, someone re-assure me that there is no way the new cat is causing more restriction than the compliance cat (which was not gutted or damaged). ie. it was a sound move, and of benefit to the system, even though i couldve gone with a more expensive option like a 5inch big body catco, but i didnt.
Secondly...what is with the boost readings?
I've confused myself, and you, no doubt. If you've read thru this, congratulations, you're more patient than i am.
https://www.sau.com.au/forums/topic/144130-lets-see-you-answer-this-onegenius/
ambient temps both the same?
you werent taking one reading from a cold night
and the other form a hot day or something similar?
either way, if both gauges have taken two different readings contrary to each other... makes me wonder about how accurate they are
boost guages are not acurate at all, also length of vacuum hoses may make some difference aswell, and guages are only a guide not a real representation of what the hell is going on, if you wanted results dyno it then see how acurate the guages are, compared to dyno result of boost, plus dont forget the error that may be seen from reading at an angle, same as if passenger looks at your speedo from an angle it will look different to what it really is, same as if you go by your speedo guage then your stupid as 99.9% of them are in accurate.
My opinion on this
Not only saying that, how do you know there isnt the slightest leak in one of the vacuum to guage hoses??? :S
Edited by Devils_Advocate21
i understand that gauges arent accurate etc. and leaks can cuase bad readings.
but...the gauges were reading about 0.5psi apart, and now they're reading 1 psi apart in the opposite direction.
u see?
also, is it even possible that a highflow cat can cause more restriction than the standard cat?
even if it is the cheap xforce option i went with?
the readings were at the same time, so same temp.
had a passenger reading the one in the glove box.
So... took inital reading... fitted cat, went for a drive immediately after fitment and took another?
Thats weird.
The gauges should be accurate, that is if your not running 11ty billion meters of hose...
was your old cat stuffed? collapsed inside?
Thats weird.
no, i didnt explain that properly, or you misundertood :D
the readings before and after the cat were not taken on the same day.
what i meant was, the readings showing the difference between the gauges is taken at the same time. ie, i'm not going out, reading one gauge, then coming back in, swapping etc, then out for another reading.
but i'm still baffled as to how one gauge showed higher by 0.5psi, and now it's showing lower by 1psi.
if the gauge on my steering column is correct, then changing the cat netted me extra flow which resulted in ~0.5psi gain (i'm happy with that).
If the other gauge is correct, then changing the cat actually cost me flow, losing about 1psi (not so happy).
the standard cat looked to be fine inside. all mesh intact, no loose rattling, etc.
Where does the hose going to the BOV come from?
If it comes from the plenum, they usually do, then my guess is the BOV is leaking 1.5 psi.
:D cheers :)
:D cheers :)
hmmmmm, interesting. yes it's coming from the plenum.
why now though? why not before the cat? is it maybe an extra 1psi that did it?
it's a gfb hybrid bov (full plumback), and the spring is set to quite soft. would tightening the spring fix a leak?
if not, how do u fix a bov leak?
Have you tried swapping the vacuum lines to see if you get the same readings?
yeah i was going to replace the line to the gauge that reads low, and see if it was just that.
but i'd also like to know how to check/fix a bov leak.
will tightening the spring on the bov do anything for a leak?
so how do you check for, and fix a bov leak ? (gfb hybrid bov)
if there was a leak somewhere else, it would affect both gauges equally, correct ?
Check is easy, disconnect the vacuum hose from the BOV and block it off. Then compare the gauges. If the guages now read the same, then you know you have a leak. So check the hoses and the clamps between the BOV and the plenum, a 1.5 psi leak is easy to have and hard to find. If you can't find any leaks then it's the BOV, try tightening it.
:nyaanyaa: cheers :happy:
did you have the same person reading gauge b both times. and were they looking at it at the same angle. or maybe the person just rounded up, or the needle had flickered.
go for a drive and look at gauge a and have someone look at gauge b. then compare readings. then swap places and repeat. then you will be able to tell if it is how the other person is reading the gauge.
yeah, i thought of that. and i will get someone to video cam the gauge so i can check it myself afterwards. lol.
but all this heat in syd right now. not the best time to be pushing the skyline. might wait for a cooler day.
i might just change the hose from the plenum to the bov, and then see what the reading says.
what diameter is that hose anyway?
i put a new silicon hose on from the plenum to the bov, with a new T-piece just before the bov, running to gauge B. all very secure, i cant imagine there's any leaks in the line.
gauge B is still reading 1 psi lower. tonight is a cold night, so i got 10psi on A, and 9psi on B.
the bov itself is bolted up well.
what bothers me is that there might be a pressure leak somewhere, hence the readings.
will adjusting the spring on the bov, to a harder setting, make a difference?
any others ideas of what to try, or where to look?
no, i havent swapped the gauges over.
i guess i should try that. the reason i havent is that the drivers side gauge is a bitch to remove, and the hoses in the engine bay arent long enough to swap over. i might extend the hoses and try that next.
yeah damn it, wouldnt you know it, it was the gauge playing up.
swapped gauges around and the bov line showed 9psi, while my factory nipple showed 8psi (with gauge B).
so gauge B was giving a false reading.
i shouldve tried this first, but i didnt imagine the gauge would all of a sudden give a false reading, after reading consistently for so long.
anyways, let that be a lesson to me.
good news, there's no leak :D
thanks for the help :D
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
