  • Replies 54
Posted Images
In theory it should handle any boost level I would have thought. The valve has the same pressure on both sides of it at all times when your on boost.
Only when shifting can it be a problem, and event then the down side is that the bov doesn't flow enough to allow it to stop a pressure spike back through the intake plumbing and reducing turbine speed.
ive been told the standard bov will leak at 14psi, when i got my car tuned by hitman he said i had a boost leak somewhere and all of my pipes were perfect.
i bought a 2nd hand gtr bov which can handle way past 1 bar :)
Does the gtr bov bolt up with no mods or?
I recently blocked the std bov's bleed hole and boost went up a psi.
GTS4Newbie,
Give this a shot.. Block your bov off. Run no bov.
Take it for a drive and experience your turbo doing the exact opposite as to what you suggest. The car really does get up and go much quicker after a gear change when running no bov.
My own thoughts are that yes there is a pressure spike but not having the bov release the pressure essentially prevents the lag that you experience with a bov when the turbo has to spin up and fill the ic piping and fmic again. With no bov the majority of the air is still there so the turbo quickly spins up a little and is up on boost quicker.
This is what I experienced. Give it a shot. :)
I did however experience a horrible jerky driveability issue when changing gears at part throttle and low rev's. Changing up at 3500rpm or so and driveability was fine.
I also had the odd stall under certain circumstances but nothing I couldn't work around.
The results with the blocked off bov were that good that I'm tempted to put up with the jerkyness when changing up at 7psi or so with part throttle at 2000rpm. It really did feel like it was instantly on boost when grabbing the next gear.
Anythin above 15psi the bov will leak and not do its job!
My changes are so much smoother with a decent bov + plumback section set up, mind you i do run 20psi through a bigger turbo which is producin alot more air-flow than the stocker would!
If you are runnin 1+ bar id change it even on stock turbo...
If your running 1+ bar on a stock turbo, you'll need Gilly out back to catch that turbo wheel!
I have heard of several stock GTS-t BOVs dying on not much more than 12psi so I would upgrade to GTR or aftermarket for 1bar+.
Well guys i run the stock GTR plumb backs, and i boost nearly 2 bars. so the GTR BOV does its job in my application, it flows enought to take 23psi of T04Z pressure, cuz i dont get any surge issues.
My son and I tested his stock BOV on his R33.
We made up bungs, plugs etc, removed the BOV recirc. pipe and pumped up the complete inlet pipework including FMIC to 2.0+bar.
Results were fine. Just a slight leak which remained at 2.0bar or 0.5bar.
Then we swapped the BOV for my old R32's one and exactly the same story.
With ingenious valving we snapped the BOV open and shut and the tiny amount of leaking continued, it's only a metal to metal valve seat after all.
At 1.3bar, his 2835 had heaps in reserve to more than compensate for the BOV leak, but if you're pushing a stock turbo to 1.0+bar, you'll have more to worry about than a BOV leak.
Did you plug up the std bovs bleed hole?
No, the BOV was as installed but with the recirc. hose off so we could gauge how much air was leaking.
I run a std r33 bov on my car which runs up to 20psi. Its simple physics unless the bov is completely f**ked it cant possibly leak. The plenum side has pressure on a larger area than the pre-throttle body pressure, it cant leak.
there are benefits of leaving that hole unblocked. 1 is that when at WOT there is a small amount of air being released through it back into the intake. this negates a vacuum effect happening which would suck the bov open at higher boost pressure.
hrmm not so sure on that theory Mad082.
If there was enough vac to over come the spring pressure + the added equalised boost pressure some thing would be quite wrong with the intake pipe.
From my own experience all it does is smooth out throttle making it nicer to drive, with the blocked its very on/off and can cause a bit of a jolt under certain circumstances.
With it blocked it makes boost earlier and without touching anything else it makes 1psi more once on boost.
It also won't release the bov when making boost at say 1/2 throttle then backing off to 1/4 throttle, the turbo just keeps boosting, very noticeable driving up hills as its difficult to keep off boost where as before cruise up a hill and providing acceleration was steady it would be off boost.
    • Thanks! Will get it looked at before winter 🥶 other than that she's a mint ride love it aye
    • FWIW a lot of the local owners that do a big build tend to have cars that are perpetually broken.
    • I just got this system but haven’t installed yet I got a Moroso sealed box (defect reasons) which will be set up same as their pic The quality is high grade, the correspondence I had with the owner (former head designer for Rockford Fosgate) was unbelievable, guiding me with what I needed. Even told me not to buy some things as it could be sorted in a different way at his loss. Just a bit of a bite with the exchange rate and don’t purchase gear in 1 hit that goes over $1,000 au, lol I forgot!
    • Thanks mate for that reply. Very helpful.    it’s a 2022 400R so would most likely lose those features as you say.     I did a quick compare of a rv37 nav and heading for sale in Japan to q50 model. I’ll pop pics below. Seems  Japan spec head into top, nav unit second below it   below pic Q50 aud delivered     differences seem to be Aus delivered has a different plug top left hand side of head unit- not sure what and where it goes.   and nav unit Japanese tv37 had an extra plug put    Again I’m really not sure what each of these differences mean!       the actual plugs on a v37 and q50 screens look identical on both screens… pics below for comparing. (One screen was is a us delivered one) but should be same gps signals etc as Australia.    If it were as simple as swapping a nav unit from q50 aud delivered im interested -just want to figure out what the missing plug is for before spending big $ on a second hand part for it to not work, and I guess with the head unit, if the band expander does the job (I got a 20mHz so should get the range I’m after) so should narrow my issue down to nav unit only.  I’d love to know what the extra cable on rv37 does and if I eliminate that part what it’ll do to the setup,    and also, if I can figure out what that head unit plug difference is, what does that cable do and where does it got can it be altered or re-plugged?! Excuse my ignorance what is ACP/AA, what does that stand for? (Apple car play? Android air play)? so If I swapped head units to save using a band expander, I’d likely lose those better features to have an oem Unit operational. Better to use a band expander and retain AirPlay options and newer version of head unit     provably best to band expand it, and focus on the nav unit. th isn’t  a big deal/ would be cool to have it working  from what I can tel we use a PAL Signal and Japan uses a NTSC signal  I don’t know if there’s a co better or if the screen only reads NTSC, or if it’s the tv module that needs replacing… no big deal don’t need it but more of a curiosity thing on that!   Thanks for the info re tyre sensors, helpful and great to know.  I was reading the online manual off Japan website and it seemed to make it sound more confusing than it is  I guess a rim replacement would require the sensors to be moved to a new rim to carry that option over?!     Thanks for the info regarding diagnostic mode. I appreciate your help mate. Trying to brainstorm here to find a solution to get as much gadgets as I can working! I plan to get my local Nissan tech to have a look too who used to be at an Infiniti dealer back in the day to see if any thing they have or idea can find a soliton. But hoping anyone here has gone down the same route to make life easier!!   i guess identifying the cable/plug differences and what they do would be a great way of finding out if the units are transferable    thanks again
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
