  • Replies 89
Posted Images
more the merrier.... :D
Paul, do you think it might be possible for us to park on the platform like last year? the caravan park would be great to use again :) but no space for parking... is there? otherwise maybe Spencer Park would be a goer.
only problem with spencer park....as you said before, could be busy on a sunday so close to christmas. what is its carprk like? i'm guessing we will need to find parks for around 15-20 cars...
I saw an ad on TV for a fireworks display happening up there on the night of the 17th at one of the parks. (Sorry for being so vague). So they may be setting up festivities in one of the parks we had in mind for our luncheon,
:thumbsup:
you might get lucky :laugh: ....not many 4 doors around.
hmmmm, will have to check it out about the fireworks. well even if we just stay in the carpark at the boatramp, all will be good :P
no car parks at Spencer Park just the kerb spots surrounding it, but there is great shade and has gas bbq's...ill chat to Steve Paul at the caravan park to see if their bbq's can be used by us.....depending on bookings we may be able to park on the grass in the caravan park...but that decision will be up to Steve and one he will only make on the day.
No chance...its now a boat yard...like a car yard but full of new boats...inconsiderate ba5tards!
lol.....damn
i'm thinking if we cannot use the caravan park, we just take or buy some lunch, and chill at the boat ramp carpark.
might be better just to take/buy lunch anyway. might save a lot of fuss :D
sound ok everyone?
Buying lunch will be a pain in the arse, since the only take away there is bloody expenisive and not all that good.
Smallest portions I've ever seen!
We could just go somewhere else in the bay, like over to Fingal or something.
They have a top take away and some great views.
might be a goer then :)
takeaway is prob best
Well, seeing as we are all leaving from Speers Point, it shouldn't be too much hastle to change destination.
also, if anyone has uhf radio's.....bring em along. (with good batteries) :)
Yeah and I think cruising through the middle of Nelson Bay will definately turn some heads!
Of course we could just stop in the bay, but it's all paid parking.....yuck!
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
