Rocker cover gasket change in a series 1 R33 GTS-T (RB25DET):
Disclaimer:
Do this at your own risk! I accept not responsibility for injury or damage to any part of the engine or otherwise as a result of following this guide.
For Torque specs and other specific instructions, see the bottom of this post.
What you will definitely need:
New gasket(s) from nissan
New rear cam-shaft seal(s) from nissan
Gasket goo
Large phillips-head screwdriver
Medium phillips-head screwdriver
Spanner set
Socket set
Allan key set
Around an hour - more if it's your first time.
What you don't need but should probably use:
Carby cleaner
Relatively clean rags/towels
Throttle body gasket
1. Go to Nissan and purchase the rocker cover gasket(s) you require. This guide goes through the process of replacing both.
Part numbers for RB25DET:
LEFT (exhaust side) gasket: 13270-58S01
RIGHT (inlet side) gasket: 13270-58S11
(Consult your nissan dealer to be SURE of this. I am fairly confident that I have left & right correct. I bought both for $72.05.)
'Half moon' Cam gear seals: 11051-58S00
2. Pop the bonnet.
3. Remove the crossover pipe.
There are a number of things that you must disconnect/unscrew to fully remove the crossover pipe and associated bits and pieces. These are highlighted in red on the image below.
It would be worthwhile putting a clean cloth in either end of the crossover now that it is removed, and also in the throttle body to prevent any unwanted debris entering the engine.
4. Now remove the two hoses on the rocker cover breather:
Mine split when removing as they are very stiff hoses. I will need to get new ones from Nissan and I will update this with part numbers when I do.
5. Remove the coilpack cover.
Disconnect the two connectors highlighted in red below, and then use the appropriate Allan key to remove the 8 screws holding the coilpack cover to the rocker covers (highlighted in blue)
6. Unscrew the left rocker cover
Take particular note on how tightly these screws are done up: NOT VERY TIGHTLY AT ALL. Remember not to do them up very tight when you put the cover back on. just to the point where u can see the rubber washer undergo a bit of pressure. Torque specs are at the bottom of this post.
Also, on some screws the rubber grommet will also come out with the screw, on others it will not. Do not lose these grommets!
Be very careful not to let any dirt or other crap into the engine, or into the rocker cover.
The 10 screws are highlighted on the image below (right hand side not visible)
Removing the rocker cover will now expose your camshaft:
7. Remove the old gasket from the rocker cover, and replace with the new one.
Use gasket goo or sealant on the raised half circle on the front side of the cover, highlighted below:
While I had the cover off, I cleaned the outside with Carby cleaner, being extra careful not to get any inside the cover.
Use a pair of needle-nose pliers to gently lift the old half-moon rubber from the back of the rocker assembly (highlighted in red below). Coat all outside edges of the new half-moon with gasket goo, and then reinsert it.
8. Replace the left rocker cover by replacing the screws
Remember, not too tight at all.
The process for removing the right cover is slightly different:
9. Remove the screws on the right of the cover.
Note that there is also smaller screws that need to be removed, that are currently supporting the wires:
Either that or unfold the support and remove the wires. I did it the hard way.
10. Remove the screws on the left of the cover.
Removing the screws on the left of the cover is more tricky. If you have an angled screwdriver, go for it right now! If not (I didn't) you will need to unbolt the throttle body assembly.
There are 4 bolts you need to undo. well, actually two nuts on the top, and two bolts below.
The top two nuts can be done with a spanner. Use sockets for the bottom bolts, as if you use a spanner you will need to remove the Throttle Position Sensor.
Once the TB is unbolted, unhook the throttle cable from it's position and carefully lift the TB out of the way, allowing you access to the rocker cover screw beneath.
The gasket may break in this step, so it would be handy to replace it while you are doing this. I didn't have to, but probably should have :)
Throttle body and throttle cable (red) and TPS (blue):
The top screw is tricky, but just involves holding a lot of stuff out of the way to get to it. Magnetic screwdrivers work well here.
11. Repeat steps 7 & 8 for this side, and then perform steps 10, 5, 4 & 3 in reverse order.
If putting the allan key screws back on the coilpack cover is proving difficult, try tightening the inner screws of both rocker covers just a little to bring them closer together.
Make sure everything that was disconnected is now properly reconnected, and all hose clamps are tight.
And you're done:
12. Start 'er up!
An abridged (but specific) guide from a workshop manual is as follows:
Hope this helps :(
Edited by Mike_
https://www.sau.com.au/forums/topic/144235-changing-the-rocker-cover-gasket/
Co-incidentally I have just done this today!
I don't see any mention of the half-moon rubbers that should really be replaced. You highlighted and said to put goo around that area, which is correct. (or goo the half-moons before you put them in).
Anyhoo, they're a seperate part number, and apparently these motors leak from there before they leak from the gasket, so while you're already there:
7. use a pair of needle-nose pliers to gently lift the old half-moon rubber from the back of the rocker assembly. Coat all outside edges of the new half-moon with gasket goo before reinserting.
Edited by RANDY
I don't remember seeing any half moons aside from the raised half circle part of the gasket itself...
I'm not too familiar with mechanics in general but I know enough to get me by, so it's likely that I missed this.
Can you give me any photos of what you're referring to?
the rear camshaft seals is what he means. Half moon that slips in the back half moon cutout...but by the sounds of it the new rocker cover seals have them built in now. Good idea nissan!
Nope! I can see the gasket pics, and they don't have the half-moon built in. They ARE a different part number, and I had to ask for them seperately. I bought mine 2 days ago now, and they weren't built-in.
So you guys above who say you can see it built-in, that raised arch is for the front, but the rear camshaft seals (half-moon) can come out. When in, it makes the back flat, which sits flat against the flat part of the rocker gasket/cover.
I didn't take pics, but next time someone is doing this, they will be able to see what i'm talking about... as R33_racer mentions also.
So if you're still leaking oil around the back, and down onto your gearbox, those half-moons will need to be replaced and resealed! =-]
  • 4 years later...
just about to do this job n have a query for those out there that have done it...
some of the little rubber grommets that sit under the screws around the end of the cam cover n hold it down look pretty perished on mine.
are these something that also needs to hold an oil seal and therefor need to be in good condition or what?
n if they do need to be in decent condition are they just a standard grommet or are they something im going to need to source the specific OEM part for?
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
