Hey all, I'm the ex owner of a sexy c33 laurel - really wish I didn't sell that car... Anyway,
In regards to the rb20e motored auto a31 cefiro, what needs to be done in regards to an rb20det manual swap...
Are the brakes the same as the stock rb20det cefiros, do the rb20det bolt straight in, is the gearbox the same as far as autos go and is it any harder to put a manual in because of the whole rb20e thing.
How about the diff in the rb20e, is it a VLSD like the turbo models?
Thanks, Any info would be really really good, I need it quickish
Cheers boys
Gavin
https://www.sau.com.au/forums/topic/144239-cefiro-base-models-to-rb20det-swap/
hey buddy,
the non turbo never came wit VLSD (only turbo)
um the brakes shud be the same as the s13 so i think you'll need 2 upgrade to sr20det (ca18det brakes are shit 4 a rb) brakes nd disks (not 100%)
not too sure if your doin this your self but... a decent-ish price on da manual covertion installed with parts and rb20det gear box shud b around 1.5 grand
if u are doin it your self(nd not a mech) u will have sum headache's but is doable..... and dats if u have a guide 2 follow lol
p.s wat state u located in?
Edited by Dan_J
quick question, sort of off topic....
I have a RB20E Manual 5-speed Tranny... im 85% sure its the same as what comes on a RB20DET... anybody know for sure? i think the NA and Turbo are different im talking specifically the flywheel...
Edited by 4DoorWhore
^ um the rb20det is stronger then the rb20de, you can use the rb20de box if you wanna go cheap, i think the gear ratio is a lil dif ( not too sure). although you'll probly blow it at sum point seeing the you live in jap and have nice roads 2 play with
They have different housings, but the internals are pretty much the same. It's not worth it to swap in a turbo gearbox.
Not true, as far as I know they never came in any single cam models though. Lots of DE Cefiro's with the five speed auto came with the VLSD.
Check here: http://d1nz.org.nz/forum/viewtopic.php?t=2541 Most of your questions have been answered.
Edited by open24hours
well i didnt wanna give you the back story but ill make it quick.... i sold the manual tranny and all the components to a mate here in japan to do a auto to manual swap... but my dumbass left my flywheel on my wrecked R32 GTSt and off to the junk yard it went....
so instead of buying a $150 dollar flywheel, i considered just using the one from my Cefiro motor (an RB20E not a DE) since im gonna rip out the motor anyways and throw it away when i put the SR in next week.
so yeah im just wondering about the Flywheel not the entire tranny since i have a DET tranny minus flywheel.
sorry again to sort-of thread jack....
thanks didnt bother to try, found a new clutch and fly for $150 so im not complaining.. and my cefiro remains drivable at the same time... still slow but drivable... man i need to finish this SR
    • So where is this message group so we can organise another meet? Keen to come along and catchup. Might eventually be in a skyline again next year, but the Mustang will have to do for now. Also need to get the WRX back on the road. Stupid f**king money pit that thing is.
    • Stock equivalent turbo replacement is a bit of a nightmare. The old Hitachi ceramic things were pretty good for their time, but they have primitive, vintage aerodynamics. The only thing they have going for them is a light turbine**, and there are plenty of other light turbine options these days, in both materials and CNC manufacturing methods. So, the old stocker makes absolutely no power at all compared to its physical size and its (not very low) boost threshold and response. ** and the ONLY thing that was good about the ceramic turbine was that it was light. In all other respects it is a nightmare. To get a turbo that is anywhere near equivalent in terms of power capacity (ie, to avoid it being "bigger" and needing tuning/fuelling/etc) you have to physically downsize. And that is not a "stockish" replacement. Doesn't just fit where the old one did. At least a frame size down, probably need a new dump, probably need new inlet and outlet piping made on the compressor side, new hose connections as D said above. I say, if you have to suffer that much work, you might as well do the same work to fit an even bigger (than stock) turbo, have more power (and hence have to do injectors, ECU, etc), and love life, instead of suffering with stock power levels. Or, you get a light highflow from someone like Hypergear. A highflow that has not been pushed too far from stock. There are still modification consequences here though. HG's cores are smaller than the massive Hitachi core, so it is shorter, moves the compressor housing backwards and requires mods to the air side piping. Plus new hoses. Looks stock, mostly fits where the stock one did (with the previous caveats mentioned), makes a bit more power but can be run at stock boost levels and not cause too many ECU problems. But, seriously. It's 2024. Like - 25 years since the R33 came out. It's time to put an ECU in it. I Nistuned my car (on RB20 ECU then later again on the Neo ECU) and it was the single best thing possible for minimal money. Dial out the R&R bullshit, fix up the fuelling and timing to make it more efficient for normal driving (cut fuel consumption by >10%). Nistune is not an option for you unless you change the ECU, so you might as well just do a standalone. it will be worth it. And then you can tune it up to the limits of the injectors and AFM, which is pushing 200rwkW and enjoy some actual squirt, instead of the lazy barge-like motion you get from a stock engine, turbo and management.
    • He can't post pics until he's at 10 post count.
    • Welcome James.....will be interesting to see how much fun there is in the project. .....where's the pics?
