Hey,
after going down to WSID one nite in my R32 GTS-T , i noticed there was a loud whine coming from my diff. i went to my mechanic and he told me it was my diff bearings. now my problems comes here, he told me that i could get new bearings put it in or i could get a second hand diff and put it in.
ok, now im looking at getting into track work, drift and circuit, i was wondering if getting a centre would fix my problem or do i have to replace the whole thing?
i was looking at getting an LSD either 1.5 way or 2 way, not really fussed whicheva comes my way and ive read up on the types and dont mind either at all,
is there much of a problem buying a second hand mech diff or would i be better off buying a brand new one? i dont want to spend too much on it but if i need to i will. ive looked at shimming it up or locking it but it doesnt appeal to me much and would rather go the right way about it.
are there any other options?
any help would be appreciated
Thanks
Stephen
https://www.sau.com.au/forums/topic/144240-diff-help/
A 2way in many ways is very simlar to a locked diff, so if you dont want a locked diff I would suggest 1.5way.
Brand new Kaaz diffs can be had for $1050 delivered, and they include the bearings. All you have to do is get it put into the housing.
2nd hand mechnicals go for about 800-1000, but usually in housings already so just bolt in, so the question is, do you want to spend another 200-400 to get a brand newie?
But with the brand new diff you do have to do break in, change oil a lot, etc. But you do have peace of mind.
https://www.sau.com.au/forums/topic/144240-diff-help/#findComment-2697122
hhmmmm... so there isnt much difference in prices between a new and second hand mech diff.
i think i mite go the brand new one unless i can find a cheap second mech diff, coz its not that much difference and as u said i would have piece of mind.
where can i get a kaaz for 1050 delivered? places ive checked are usually around the 1200 mark?
thanks
Stephen
https://www.sau.com.au/forums/topic/144240-diff-help/#findComment-2697770
thanks heaps for ur help salad.
after alot of searching on information about diffs and such, im having second thoughts about getting a brand new diff centre as it seems like a fair bit of dough for me to spend where i could put it elsewhere to the car. ima have a think about it a bit more and see where ill go from there
Stephen
https://www.sau.com.au/forums/topic/144240-diff-help/#findComment-2699098
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
