Hey,
after going down to WSID one nite in my R32 GTS-T , i noticed there was a loud whine coming from my diff. i went to my mechanic and he told me it was my diff bearings. now my problems comes here, he told me that i could get new bearings put it in or i could get a second hand diff and put it in.
ok, now im looking at getting into track work, drift and circuit, i was wondering if getting a centre would fix my problem or do i have to replace the whole thing?
i was looking at getting an LSD either 1.5 way or 2 way, not really fussed whicheva comes my way and ive read up on the types and dont mind either at all,
is there much of a problem buying a second hand mech diff or would i be better off buying a brand new one? i dont want to spend too much on it but if i need to i will. ive looked at shimming it up or locking it but it doesnt appeal to me much and would rather go the right way about it.
are there any other options?
any help would be appreciated
Thanks
Stephen
https://www.sau.com.au/forums/topic/144240-diff-help/
A 2way in many ways is very simlar to a locked diff, so if you dont want a locked diff I would suggest 1.5way.
Brand new Kaaz diffs can be had for $1050 delivered, and they include the bearings. All you have to do is get it put into the housing.
2nd hand mechnicals go for about 800-1000, but usually in housings already so just bolt in, so the question is, do you want to spend another 200-400 to get a brand newie?
But with the brand new diff you do have to do break in, change oil a lot, etc. But you do have peace of mind.
https://www.sau.com.au/forums/topic/144240-diff-help/#findComment-2697122
hhmmmm... so there isnt much difference in prices between a new and second hand mech diff.
i think i mite go the brand new one unless i can find a cheap second mech diff, coz its not that much difference and as u said i would have piece of mind.
where can i get a kaaz for 1050 delivered? places ive checked are usually around the 1200 mark?
thanks
Stephen
https://www.sau.com.au/forums/topic/144240-diff-help/#findComment-2697770
thanks heaps for ur help salad.
after alot of searching on information about diffs and such, im having second thoughts about getting a brand new diff centre as it seems like a fair bit of dough for me to spend where i could put it elsewhere to the car. ima have a think about it a bit more and see where ill go from there
Stephen
https://www.sau.com.au/forums/topic/144240-diff-help/#findComment-2699098
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
    • Hopefully not, since he knows the fuses work ha ha ha
    • I don't think he's got it on a gauge and on the ECU. I think he's got it on the gauge and on the HPTuners DAq thingo. Remember, we're talking about oil temp here, not something that the ECU is actually interested in for its own sake.
