Hey guys im selling My silver R34 gtt. Comes with many extra's:
- HKS 2540 turbo
-Hks front mount intercooler
-Trust airfilter
- Bosch in-tank fuel pump
-Hicas lock bar
- Apexi power fc
- Profec-b boost controller
-full Trust power extreme 11 exhaust
- front/dump pipe
There are other parts that i cant think of at the moment. plus it also has four 6x9 speakers and 2 10 inch subs.
Rego till 07.07
Asking for $26,000 fully negotiable.
I can also take out parts to make it cheaper.
Only willing to trade for a 180sx or s13 plus money ontop.
You can contact me at [email protected]
cheers,
Struan
Edited by FLIP
https://www.sau.com.au/forums/topic/144268-silver-r34-gtt-for-sale-sydney/
Oh sorry i did a quick reply, but for some reason it did not show up. Anyways here are the details. It's a 1998 model. Manual transmission and has around 105,00k's. i'm the first australian owner and i bought it from Edward lee's Japanese auto centre. It had over 60,000k's when i bought it.
Other things is it also comes with a full alarm system and an excedy heavy duty clutch.
Edited by FLIP
cool, sounds good, i have a cousin of mine in canberra having a look at a couple there for me cos im in perth. But if they dont end up being good ill let you know, i'll send someone over to have a look.
Its good having cousins in every city haha
yeh i'm interested, but pity im in perth
been shopping for one for a while here and cant find one with that many mods at ur price here
i'll have to see how much its gonna cost to get a car from sydney to perth first
or u might know?
Ztuned- hi mate, sorry i wouldn't know hoe much it cost to get it over there but i doubt it would be that much. Prob a few hundred dollars to put it on a truck. It should be pretty easy to find out though... Let me know how you go. Cheers
Just a quick question FLIP , how much boost was the car running when the car made 220rwkw and also did you do all of the mods yourself or were they already on the car when you got it?
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
