i will need new set of tyres for my R33 GTR soon.. i currently have bridgestone grid2 in 245/45/R17 size.. the rims are stock gtr ones.. i went down to bridgestone parramatta today and they didn't have 245/45/17s... (only in pirreli which was $495 per tyre...)
best offer was $395 per tyre for potenza S03 in 255/40/17...
r there any better valued tyres?? i don't wanna pay too much buy do really want to compromise the grip, handling etc etc coz i want to goto track days with new tyres too...
any help will be appreciated...
https://www.sau.com.au/forums/topic/14427-tyres-for-r33-gtr/
andrew, u saying its weird that they don't have 245/45/17s ?? (my current tyres came with my car brand new from japan and it was adr approved tyres so i didn't have to get new tyres when compliancing... i was told that they don't have those sizes in australia...)
and lepperfish, which bob jane was this?? that GRB tyre was mentioned in alot of tyre related threads... and i should be okay to put 255/40/17 on my car?? (i assume so...:uh-huh: )
https://www.sau.com.au/forums/topic/14427-tyres-for-r33-gtr/#findComment-291779
No, I was saying it was weird that the S03s were cheaper than the GridIIs
The Potenza S02/S03s have for a long time been widely recognised as the best all-round tyres available. Excellent in the dry, unequalled in the wet, and good wear rates for the grip they provide...
255s are fine, but let me give you a hint: replace all four tyres at the same time, otherwise ATESSA will go bonkers.
https://www.sau.com.au/forums/topic/14427-tyres-for-r33-gtr/#findComment-291973
Nissaner,
Be careful of the load rating of the tyres you decide to get. An R33 GTR has a load rating index of 94. I recently bought tyres for my GTR and I was only able to find like 3 types of tyres that had an index that high. I even rang transport over here and they told me in an accident the tyres are checked and the load index is one of the items they look at. If you have the wrong index on your car insurance companies won't pay up.....
I had to choose between Pirelli Pzero's, Goodyear Eagle F1's and a Yokie, I went the Eagle F1 DS-G3's, unreal in the wet. Look at www.tirerack.com for comparisons...
Cheers
Brett
https://www.sau.com.au/forums/topic/14427-tyres-for-r33-gtr/#findComment-293072
Load rating is the amount of 'load' each tyre can handle at speed. It is usually in a number (ie 94) or a Kg rating (ie 620kg). It's on the placard in the glovebox or inside the drivers side door sill (where it shows you the tyre pressures...)
Even one or two numbers different is huge, I was told the difference between a 92 and a 94 is about 60kg's per tyre!!!!!
The DS-G3's are the brand new super tyre from Goodyear. They cost me $520 each, but if I had cash up front I could have got them for around $480 each (got them on 12months interest free)..
Yeah its a lot of money but I've got HKS 2530's in now so I needed the extra grip and performance for saftey....
Cheers
Brett
https://www.sau.com.au/forums/topic/14427-tyres-for-r33-gtr/#findComment-293259
Munro,
Yeah the 540's are excellent for track work, but when you are talking 5,000 - 7,000km's from a set of tyres worth around the $400 each mark it gets pretty expensive!!!!! ha ha ha
Nissaner,
A few guys I know are using them, swear by them for grip, but they are REALLY noisy and wear really fast, they are semi slicks after all.... Would be wicked as a spare set for track days or drags...
Brett
https://www.sau.com.au/forums/topic/14427-tyres-for-r33-gtr/#findComment-294898
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
