As I've somehow been bitten by the mod bug in the past 2 days I've decided that my power goal for a nice car to drive on the streets and occasionally on the track would be ~250rwkw.
Been doing abit of research and from what I gather this what I have/will have - will these be enough for a reliable 240-260rwkw output figure?
- Hi flow turbo
- Turbo back exhaust
- K&J Core FMIC
- EBC
- SS intake + pod + cai
- Bosch 040 (enough juice?)
- Sard FPR
- 440cc Injectors (big enough?)
- Z32 AFM
- Aftermarket Management (either remap or PFC)
My car has done 38,000kms, has an RB25DET Neo and manaul transmission. Completely standard internally and I plan to keep it that way. Also a few questions:
1. The 9-puck single face Exedy clutch seems to be the right clutch for this application? How much are people paying for this kit (pressure plate + clutch face + bearings).
2. Will I run into any gearbox/diff/driveshaft problems at this power? Taking into account that I don't really do any drifting and always take it easy on the box - no bang-bang shifting.
Thanks for your time. :nyaanyaa:
Cheers
Andy
  • Replies 41
- Hi flow turbo
- K&J Core FMIC
- EBC
- Sard FPR
- Z32 AFM
Thanks for your time. ;)
Cheers
Andy
The answer is tuning, keep the knock below 20 at all times, the A/F ratios no leaner than 12 to 1 and don't increase the standard RPM limit. Tip, buy a PFC now before they run out.
No idea about clutch, never used one of those.
Drivetrain will be fine.
:nyaanyaa: cheers :happy:
Excellent, thanks SK - always there as usual to help people out.
Regarding clutches: what would be a daily driver friendly clutch that can easily handle 250rwkw? Would the 9-puck I'm after seem like the best choice? I previously had a Exedy heavy duty organic clutch in the GTIR and it was very easy to drive, but I'm assuming a clutch like this is not enough for the power I'm after in the GTT?
Prior to this it did have a 3-puck Nismo-style one in the GTIR and while it was hard to press on the clutch pedal I did get use to it after a while, so anybody in Sydney with a 9-puck want to let me see what their clutch is like? :P
Thanks, Oil cooler will definately be considered if I decide to start getting serious about track work.
Adam, are you suggestion I get 480cc or saying you have 480's? The 440cc I've worked out to be able to give approx 250-260rwkw at 90% duty cycle. (440x 6/5 x 0.9 x 0.75 x 0.7 = 250rwkw).
Tomei Poncams are also cards depending on budget. How much was the Jim Berry special, could you PM with the details and price of the clutch?
That’s a conservative calculation, the 440 cc = 440 bhp includes a 20% allowance for spare duty cycle for acceleration and cold run enrichment. So 440 bhp / 1.34 = 328 kw – 65 kw losses = 263 rwkw. Up the fuel pressure from 34-36 psi (standard) to 45 psi and make sure you don’t use more than 10% acceleration enrichment and you can get to 320 rwkw pretty safely.
:D cheers :D
Why would you bother with 480cc injectors from Nismo when you can get 650cc or 800cc from SARD at the same / lower price? Surely if you're going to run a PFC you'll be able to tune to larger injectors.
My 2c on that one...
Coilpacks? Might want to replace them with Splitfires if not already...
Fuel Pump; spend that extra bit more and get a 044 setup + surge tank - get you set for the track and will support more power later on. Else buy a Nismo Pump or Tomei Pump
E-manage seems to be a good way to go these days with the PFCs getting rare as dino eggs...
Link it up with a E01 EBC and you have quite a tuneable system that controls largely everything...
Else you can always go for Haltech, Microtech, Motec or HKS :D
nicks performance clutches in brisbane make a solid but driveable clutch. Not to badly priced either, 4 of the guys around here including me run clutches by them and we all think theyre excellent. two of the guys are running 350-380rwhp and it seems to handle it fine
http://www.npcperformance.com.au/
Because larger injectors use more fuel?
Isn't it the case that the larger the injector the less 'fine' tuning you can do: Read: At idle and low rpm work the minimums aren't as precise?
Because you buy injectors that suit IMO.
Why get 600 sards? They are not a "bolt on", they need collars and rooting around.
The Nismo are a bolt in job, and will supply enough fuel for 260rwkw.
IMO - its the best choice of injectors.
As for the coilpacks - wait. Your stock ones might be 100% ok. Mine were, as many others.
Rather than spend the $600, get the car going, if you have miss firing, then spend the coin on the splitfires.
OnGsTa - if you wanna save even more cash, dont get a FPR/coil pcaks yet.
With your injector choice, there is no need for an FPR, the stock reg is perfectly fine.
Spend the money on a batter radiator and oil cooling as injected_flow pointed too. That will serve you better on a track car
[/quote
there clutches are great im using one in my rb25 cefiro, great feel and iv never had slip.. from what i member good price too, im running 1100lb pretty sure.. think bout it people speakin with experiance with the product is good thing not people sayin they heard from there cousins mates sister
Thanks guys, appreciate the feedback on the clutches. Could you guys post up what you paid for it so I can get a general idea of what they cost?
Abo Bob - the 440cc I have aren't Nismo, they're Dephi and are apparently direct fit replacement.
R31 Nismoid - I don't plan on buying coilpacks yet, I'll try the cleaning the carbon rod and silicon method first before I decide to fork out $600 odd. The fuel reg is already in my posession so I might hang onto it to see if its needed when the tune is done, if not I might just sell it off.
Wessa02 & 2gceffy: which clutch are you referring to? The twin plates or heavy duty ones?
Edited by OnGsTa
Sorry Paul, incorrect.
The JDM thing is a myth. S15 manual spec are 480cc, auto spec are 370cc. Doesn't matter where the car was sold; I did the parts number checks before getting a set.
BTW, this sort of injector would only fit with a R33 spec. SK has posted on this topic previously.
I believe the original question related to a Neo.
cheers
Edited by Dale FZ1
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
