I'm running all of those mods incl. PFC and spitfires...my duty cycle gets to about 75-80 max...never seen it go higher...I'm running 550cc SARDS.
you will need a good clutch...the stock one will go in no time...lol mine is about rooted and I'm getting a one made now.
As for the knock...I'm trying to get it under 20 all the time...but under heavy load on a hot day it may drift a bit over 30. I'm not to sure what are good values but if SydneyKid reckons under 20 then under 20 it is..
  • Replies 41
Because larger injectors use more fuel?
Isn't it the case that the larger the injector the less 'fine' tuning you can do: Read: At idle and low rpm work the minimums aren't as precise?
Wrong; get a computer with a high enough resolution and you've got no problems whatsoever... PFCs run a 24 x 24 map; which is good but limited... other ECUs are capable of running 32x32 maps so go figure. Also comes down to the tuner and how much attention they pay to getting it right.
Because you buy injectors that suit IMO.
Why get 600 sards? They are not a "bolt on", they need collars and rooting around.
The Nismo are a bolt in job, and will supply enough fuel for 260rwkw.
IMO - its the best choice of injectors.
Really? I don't remember putting in any collars or having much rooting around when my 650s were installed... all I remember was plug n play. I think your knowledge on what is now available needs updating my friend.
Best choice of injectors... depends how far you want to go. But as I said, down to the tuner - personally I'd much rather have that space to move forward than to go for something that will "just suffice" for now.
satanic you would be the first that ive heard of with no mucking around with sard injectors as they have never been a bolt in plug n play type. Ive fitted three sets to rb25's and each time we needed the collars and had to rewire the plugs to suit their own...two sets of 550cc and one set of 850cc. So unless they have changed it recently, they are still a stuff around in comparison to a nismo injector. I thought i read somehow a while back that the sards are a direct replacement for some toyota engines, thats why we needed the collars and plugs to suit.
Did you install the injectors or a workshop?
He wants 260rwkw, so thats how far he wants to go. The first post is pretty specific.
They wont "just suffice" they are more than adequate... with approx 40rwkw or more worth of headroom, or there abouts.
I think its fair to say his choice is very well educated.
Its like getting a GT42 for 260rwkw, yes it will make the power, but its not the best turbo for the job
I'll say it again; do your research - SARD 650cc and SARD 800cc injectors are a DIRECT REPLACEMENT with NO screwing around...
http://64.233.179.104/translate_c?hl=en&am.../language_tools
All I'm saying is that for the same price as the Nismo 480cc injectors you MIGHT AS WELL!
so what are the options with injectors are there any u an use from a different car (ie top feed GTR injectors) or is it best to get new ones
Im only after 440-480cc and where is the best and cheapest place to buy them
The JDM thing is a myth. S15 manual spec are 480cc, auto spec are 370cc. Doesn't matter where the car was sold; I did the parts number checks before getting a set.
correct. easy way to check is, 370cc's are purple coloured, 480cc's are red coloured.
as for the sards i beleive they are single pintle and dont atomise fuel as well as the nismos which are 4 pintle, so im led to believe :huh:
edit: not sure about rb's, although they are also side feed.. but sr20's require collars to fit sards into stock rail
Edited by mokompri
Incorrect...
Jesus, am I the only one with these injectors? Hasn't anyone else bought a set...
hahaha relax satanic.. yes u are right the sard injectors are a straight drop in for the r34 i opted for the 800's ... i needed them but hey about idle control its fine just needed some fine tuning thats all ..and yes your right it also comes down to tuner as well and your right about the single pintle as well ..hahaha
YOUR JUST RIGHT ALL THE TIME SATANIC...ahahahaha j/k
cheers
Exedy clutch is good.
Sard injectors ARE 100% drop in replacement now, they weren't previously.
GCG high flow is the one you want.
Oil cooler = mandatory.
Radiator.... = mandatory as I blew mine up and a mate did just recently also.
I'm on the same page at the moment. Looking to upgrade now too...
I need -
Turbo
Clutch
Injectors??
Air flow Meter??
Have -
ARC cooler
Front/Dump pipe
Fujitsubo catback w/hiflow cat
Power FC
Oil cooler
Bleed valve
What sort of highflow turbo are you guys using/looking at. I see so much variation in price...
I need -
Turbo
Clutch
Injectors??
Have -
ARC cooler
Front/Dump pipe
Power FC
Oil cooler
Bleed valve
The variation in price in similar sized/expected power turbos is usually the bearing type. Some of the bb style rebuilds are close to the cost of a new turbo although you end up with less installation issues and have no parts to buy/modify. To the uneducated I'd almost sound like I knew what I was going on about.
I'm going with a Slide max oversize and see how that goes. Pretty much the same list of mods as most so far. I have a set of JECS 550cc injectors to go in. Sounds like I'll need a new radiator as well.
I'm just about to put a JustJap radiator in mine. The current one I have is a copper twin core with stock top and bottom tanks which works quite well but I want to do 20 laps without getting too warm rather than then 10 I currently get.
I was just re-iterating what I have read in a few discussions on this before.
It was my understanding that if you got some large injectors say 800cc, that at 2~3% duty cycle at idle, the atomisation they create in their injection isn't as good as a lower value injector, obviously depending on the quality of the injector.
Again as I said, this was just shit i've read, nothing proven, I was just interested to see if it was true or not.
Thanks guys, appreciate the feedback on the clutches. Could you guys post up what you paid for it so I can get a general idea of what they cost?
Abo Bob - the 440cc I have aren't Nismo, they're Dephi and are apparently direct fit replacement.
R31 Nismoid - I don't plan on buying coilpacks yet, I'll try the cleaning the carbon rod and silicon method first before I decide to fork out $600 odd. The fuel reg is already in my posession so I might hang onto it to see if its needed when the tune is done, if not I might just sell it off.
Wessa02 & 2gceffy: which clutch are you referring to? The twin plates or heavy duty ones?
mine is just a modified excedy one as far as i know and it cost me about 300 from memory however my mates run the bigger ones, again im not sure if theyre the triple plates or just got a extremely strong single or twin plates but both handle 400rwhp no worries and theyre certainly not hard to use on the street slightly heavier on the pedal and got alot more bite but you get used to it real quick, I only find it a handful in the wet though.
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
