hey there guys i am a bit concern that my hand brake is not locking the wheels up. when car has stoped the hand brake still stops my car from moving its just when i pull it up when moving they dont lock. i do clutch in and i have adjusted them too.
i probally havnt adjusted them right but yeah, any help will be great
thanks
https://www.sau.com.au/forums/topic/144332-hand-brake-not-locking/
Have you checked the handbrake shoes?
Proper way to adjust handbrake is to back it right off at the lever, then tighten it all the way at the drums so it doesn't move, and then back it off 4-5 clicks. Then tighten the lever up till it locks after 5-6 clicks.
hehe my questions r for the benefit of myself and the other stupid ppl to scared to ask :O
any question you ask is stupid justin, hehehe.
the handbrake mechanism is in behind the rear rotors. you pull the rotors off to expose them.
you said you only wanted a pic of the drums shoes :(, anyway heres the Translated version. if there is still plently of meat left on the drum shoes but they have a glazed surface just do what Snowman said. if they are on the skinny side of things replace them, on that note anyone know where to get drum shoes and what price they are?
you said you only wanted a pic of the drums shoes :rofl:, anyway heres the Translated version. if there is still plently of meat left on the drum shoes but they have a glazed surface just do what Snowman said. if they are on the skinny side of things replace them, on that note anyone know where to get drum shoes and what price they are?
from the page:
"You do not know why is, but R31 (the Indian ram system) the emergency brake works like the ogre"
hahahahahahahah!!!! :laugh:
URAS make an awesome upgraded handbrake shoe for Skylines - if you plan on doing a fair bit of handbrake stuff for either drifting or motokhana's/autocross. I use them and they make a big difference over the standard shoes.
http://www.uras.com.au/
For stock ones you are probably better off at a wreckers. From what I gather it's one size fits all for skylines.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
